Divide and recycle: types and compilation for a hybrid synchronous language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hybrid modelers such as Simulink have become corner stones of embedded systems development. They allow both discrete controllers and their continuous environments to be expressed in a single language. Despite the availability of such tools, there remain a number of issues related to the lack of reproducibility of simulations and to the separation of the continuous part, which has to be exercised by a numerical solver, from the discrete part, which must be guaranteed not to evolve during a step. Starting from a minimal, yet full-featured, Lustre-like synchronous language, this paper presents a conservative extension where data-flow equations can be mixed with ordinary differential equations (ODEs) with possible reset. A type system is proposed to statically distinguish discrete computations from continuous ones and to ensure that signals are used in their proper domains. We propose a semantics based on non-standard analysis which gives a synchronous interpretation to the whole language, clarifies the discrete/continuous interaction and the treatment of zero-crossings, and also allows the correctness of the type system to be established. The extended data-flow language is realized through a source-to-source transformation into a synchronous subset, which can then be compiled using existing tools into routines that are both efficient and bounded in their use of memory. These routines are orchestrated with a single off-the-shelf numerical solver using a simple but precise algorithm which treats causally-related cascades of zero-crossings. We have validated the viability of the approach through experiments with the Sundials library.
Autre [cs.OH]
Fichier non déposé
hal-00654112 , version 1 (20-12-2011)
Albert Benveniste, Timothy Bourke, Benoit Caillaud, Marc Pouzet. Divide and recycle: types and compilation for a hybrid synchronous language. Proceedings of the ACM SIGPLAN/SIGBED 2011 conference on Languages, compilers, and tools for embedded systems, LCTES 2011, Apr 2011, Chicago, IL, United States. ⟨10.1145/1967677.1967687⟩. ⟨hal-00654112⟩
296 Consultations
0 Téléchargements
