A hybrid synchronous language with hierarchical automata: Static typing and translation to synchronous code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hybrid modeling tools like Simulink have evolved from simulation platforms into development platforms on which testing, verification and code generation are also performed. It is critical to ensure that the results of simulation, compilation and verification are consistent. Synchronous languages have addressed these issues but only for discrete systems. Reprising earlier work, we present a hybrid modeler built from a synchronous language and an of-the-shelf numerical solver. The main novelty is a language with hierarchical automata that can be arbitrarily mixed with data-flow and ordinary differential equations (ODEs). A type system statically ensures that discrete state changes are aligned with zero-crossing events and that the function passed to the numerical solver has no side-effects during integration. Well-typed programs are compiled by source-to-source translation into synchronous code which is then translated into sequential code using an existing synchronous language compiler.
Autre [cs.OH]
emsoft11.pdf (389.85 Ko) Télécharger le fichier
hal-00654113 , version 1 (19-12-2022)
Albert Benveniste, Timothy Bourke, Benoit Caillaud, Marc Pouzet. A hybrid synchronous language with hierarchical automata: Static typing and translation to synchronous code. EMSOFT 2011 - Embedded Software, Oct 2011, Taipei, Taiwan. ⟨10.1145/2038642.2038664⟩. ⟨hal-00654113⟩
241 Consultations
28 Téléchargements
