New interface
Conference papers
ZTN OBSERVABILITY FOR PARALLEL MULTI-CELL CHOPPER
Bilal Amghar 1 Moumen Darcherif 2 Jean-Pierre Barbot 1, 3
2 ECS-Lab
ECS-Lab - Électronique et Commande des Systèmes Laboratoire
3 NON-A - Non-Asymptotic estimation for online systems
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : In most industrial processes that use electrical energy as a source of tension or current, requiring a power circuit to control of these physical states.This paper deals with observability problems of the parallel multi-cell chopper. This type of choppers is a new DC/DC static power converter. After modeling of the power converter, its hybrid dynamical behavior and properties are highlighted. The observability properties of the state vector is studied from the new observability concept ( The Z(TN)- observability ). Following this observability analysis an adequate sensor placement is proposed after an observability analysis and a super-twisting observer has been proposed, that ensures finite-time convergence and robustness under bounded perturbations. That is why, its estimation by means of an observer becomes an attractive and economical solution. The suitability of the proposed strategy is proved by extensive computer aided simulations employing a comprehensive model of the system considering noisy measurements and load variations.
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-00654244
Contributor : Bilal Amghar Connect in order to contact the contributor
Submitted on : Wednesday, November 14, 2012 - 4:56:38 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:15 PM
Long-term archiving on: : Friday, February 15, 2013 - 2:25:09 AM
File
electrimacsamghar.pdf
Identifiers
  • HAL Id : hal-00654244, version 1
Collections
Citation
Bilal Amghar, Moumen Darcherif, Jean-Pierre Barbot. ZTN OBSERVABILITY FOR PARALLEL MULTI-CELL CHOPPER. ELECTRIMACS, Jun 2011, Cergy, France. ⟨hal-00654244⟩
Share
Metrics
Record views
257
Files downloads
124
