On sliding mode and adaptive observers design for multicell converter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, a sliding mode and adaptive observers are proposed for multicell converter. The aim is to solve the problem of capacitor's voltages estimation by tacking account the hybrid behavior appearing in the multicell converters. Furthermore, an analysis of convergence for both observers is introduced. Finally some illustrative results of a 3-cell-converter are given in order to show the efficiency of the designed observers. The applicability of the designed observers are emphasized by the robustness test with respect to resistance load variation.
Automatique
ACC_MG_FB_JPB.pdf (658.11 Ko) Télécharger le fichier
hal-00654257 , version 1 (21-12-2011)
  • HAL Id : hal-00654257 , version 1
Malek Ghanes, Francisco Bejerano, Jean-Pierre Barbot. On sliding mode and adaptive observers design for multicell converter. IEEE ACC (American Control Conference), Jun 2009, St-Louis Missouri, United States. ⟨hal-00654257⟩
172 Consultations
249 Téléchargements
