Tissot's table of logarithms (ca. 1880) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Tissot's table, only in manuscript form, is a table of powers, subdividing the interval from 1 to 10 in 100000 intervals. It is supplemented by the sines, overlayed on the same table. This composed table is reconstructed here.
tissotdoc.pdf (6.77 Mo) Télécharger le fichier
hal-00654454 , version 1 (21-12-2011)
  • HAL Id : hal-00654454 , version 1
Denis Roegel. Tissot's table of logarithms (ca. 1880). [Research Report] 2011. ⟨hal-00654454⟩
111 Consultations
724 Téléchargements
