Performance evaluation of direct and cooperative transmissions in body area networks
Paul Ferrand 1 Mickael Maman 2 Claire Goursaud 1 Jean-Marie Gorce 1 Laurent Ouvry 2
1 SWING - Smart Wireless Networking
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : Body area networks (BAN) offer amazing perspectives to instrument and support humans in many aspects of their life. Among all possible applications, this paper focuses on body monitoring applications having a body equipped with a set of sensors transmitting in real time their measures to a common sink. In this context, at the application level, the network fits with a star topology, which is quite usual in the broad scope of wireless networks. Unfortunately, the structure of the network at the physical layer is totally different. Indeed, due to the specificity of BAN radio channel features, all radio links are not stationary and all sensors suffer from link losses during independent time frames. In wireless networks, link losses are often coped with multi-hop transmission schemes to ensure a good connectivity. However, since the radio links are not stationary, the multi-hop routes should adapt quickly to BAN changes. We instead propose in this work a different approach based on opportunistic relaying. The concept relies on electing some sensors to support the transmission of other ones having a worst connection. Instead of changing the relay time to time, we rather select a relay node from a statistical perspective. We evaluate this approach from a theoretical point of view and on realistic simulations using the packet error rate outage probability as a performance criterion.
Type de document :
Article dans une revue
Annals of Telecommunications - annales des télécommunications, Springer, 2011, Body Area Networks applications and technologies, 66 (3), pp.213-228. 〈http://dx.doi.org/10.1007/s12243-011-0238-y〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00654696
Contributeur : Jean-Marie Gorce <>
Soumis le : jeudi 22 décembre 2011 - 17:07:35
Dernière modification le : lundi 24 septembre 2018 - 10:56:03
  • HAL Id : hal-00654696, version 1
Collections
Citation
Paul Ferrand, Mickael Maman, Claire Goursaud, Jean-Marie Gorce, Laurent Ouvry. Performance evaluation of direct and cooperative transmissions in body area networks. Annals of Telecommunications - annales des télécommunications, Springer, 2011, Body Area Networks applications and technologies, 66 (3), pp.213-228. 〈http://dx.doi.org/10.1007/s12243-011-0238-y〉. 〈hal-00654696〉
Métriques
Consultations de la notice
322
