On Trajectories Satisfying a State Constraint: $W^{1,1}$ Estimates and Counterexamples, SIAM Journal on Control and Optimization, vol.48, issue.7, pp.4664-4679, 2010. ,
DOI : 10.1137/090769788
Estimates for Trajectories Confined to a Cone in $\mathbb{R}^{\lowercase{n}}$, SIAM Journal on Control and Optimization, vol.49, issue.1, pp.21-41 ,
DOI : 10.1137/09077240X
Zero-sum state constrained differential games: existence of value for Bolza problem, International Journal of Game Theory, vol.52, issue.2, pp.495-527, 2006. ,
DOI : 10.1007/s00182-006-0030-9
Regularity of Solution Maps of Differential Inclusions Under State Constraints, Set-Valued Analysis, vol.24, issue.1, pp.21-45, 2007. ,
DOI : 10.1007/s11228-006-0018-4
Normality of the maximum principle for nonconvex constrained Bolza problems, Journal of Differential Equations, vol.243, issue.2, pp.256-269, 2007. ,
DOI : 10.1016/j.jde.2007.05.005
L ? estimates on trajectories confined to a closed subset ,
URL : https://hal.archives-ouvertes.fr/inria-00636415
Sensitivity Interpretations of the Costate Variable for Optimal Control Problems with State Constraints, SIAM Journal on Control and Optimization, vol.48, issue.5, pp.3297-3317, 2010. ,
DOI : 10.1137/080732614
A Connection Between the Maximum Principle and Dynamic Programming for Constrained Control Problems, SIAM Journal on Control and Optimization, vol.44, issue.2, pp.673-703, 2005. ,
DOI : 10.1137/S0363012903430585
Classical Solutions of Differential Equations with Multi-Valued Right-Hand Side, SIAM Journal on Control, vol.5, issue.4, pp.609-621, 1967. ,
DOI : 10.1137/0305040
On nonconvex differential inclusions whose state is constrained in the closure of an open set. Applications to dynamic programming, Differential Integral Equations, vol.12, pp.471-497, 1999. ,
Regularity of minimizers and of adjoint states for optimal control problems under state constraints, J. Convex Analysis, vol.13, pp.299-328, 2006. ,
Normality of the maximum principle for absolutely continuous solutions to Bolza problems under state constraints, Control and Cybernetics, vol.38, pp.1327-1340, 2009. ,
Filippov's and Filippov???Wa??ewski's Theorems on Closed Domains, Journal of Differential Equations, vol.161, issue.2, pp.449-478, 2000. ,
DOI : 10.1006/jdeq.2000.3711
Existence of neighbouring feasible trajectories: applications to dynamic programming for state constrained optimal control problems, Proceedings of the 39th IEEE Conference on Decision and Control (Cat. No.00CH37187), pp.21-40, 2000. ,
DOI : 10.1109/CDC.2001.914654
Lipschitz Continuity of Optimal Controls for State Constrained Problems, SIAM Journal on Control and Optimization, vol.42, issue.5, pp.1727-1744, 2003. ,
DOI : 10.1137/S0363012902404711
A theorem on existence of neighbouring trajectories satisfying a state constraint, with applications to optimal control, IMA Journal of Mathematical Control and Information, vol.16, issue.4, pp.335-351, 1999. ,
DOI : 10.1093/imamci/16.4.335
Degenerate Optimal Control Problems with State Constraints, SIAM Journal on Control and Optimization, vol.39, issue.4, pp.989-1007, 2000. ,
DOI : 10.1137/S0363012998340223
Optimal Control with State-Space Constraint I, SIAM Journal on Control and Optimization, vol.24, issue.3, pp.552-562, 1986. ,
DOI : 10.1137/0324032
