Statistical Analysis of the Global Geodesic Function for 3D Object Classification, 2007 IEEE International Conference on Acoustics, Speech and Signal Processing, ICASSP '07, pp.645-648, 2007. ,
DOI : 10.1109/ICASSP.2007.365990
Theory of reproducing kernels. Transactions of the, pp.337-404, 1950. ,
Robust and efficient estimation by minimising a density power divergence, Biometrika, vol.85, issue.3, pp.549-559, 1998. ,
DOI : 10.1093/biomet/85.3.549
Multidimensional binary search trees used for associative searching, Communications of the ACM, vol.18, issue.9, pp.509-517, 1975. ,
DOI : 10.1145/361002.361007
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
DOI : 10.1109/34.121791
Principal warps: thin-plate splines and the decomposition of deformations, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.6, pp.567-585, 1989. ,
DOI : 10.1109/34.24792
Geodesic Interpolating Splines, International Conference on Energy Minimization Methods in Computer Vision and Pattern Recognition, pp.513-527, 2001. ,
DOI : 10.1007/3-540-44745-8_34
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.57.7394
Spectral Correspondence for Deformed Point-Set Matching, International Workshop on Articulated Motion and Deformable Objects, pp.120-132, 2000. ,
DOI : 10.1007/10722604_11
A new point matching algorithm for non-rigid registration, Computer Vision and Image Understanding, vol.89, issue.2-3, pp.44-51, 2000. ,
DOI : 10.1016/S1077-3142(03)00009-2
A new point matching algorithm for non-rigid registration, IEEE Conference on Computer Vision and Pattern Recognition, pp.44-51, 2000. ,
Estimating the components of a mixture of normal distributions, Biometrika, vol.56, issue.3, pp.463-474, 1969. ,
DOI : 10.1093/biomet/56.3.463
Curvature Guided Level Set Registration Using Adaptive Finite Elements, IEEE Conference on Pattern recognition, pp.527-536, 2007. ,
DOI : 10.1007/978-3-540-74936-3_53
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.88.2506
Maximum Likelihood from Incomplete Data via the EM Algorithm, Journal of the Royal Statistical Society. Series B (Methodological), vol.39, issue.1, pp.1-38, 1977. ,
Rigid, affine and locally affine registration of free-form surfaces, International Journal of Computer Vision, vol.13, issue.2, pp.99-119, 1996. ,
DOI : 10.1007/BF00054998
URL : https://hal.archives-ouvertes.fr/inria-00074451
Simultaneous Nonrigid Registration of Multiple Point Sets and Atlas Construction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.11, pp.2011-2022, 2008. ,
DOI : 10.1109/TPAMI.2007.70829
A classification EM algorithm for clustering and two stochastic versions, Computational Statistics & Data Analysis, vol.14, issue.3, pp.315-332, 1992. ,
DOI : 10.1016/0167-9473(92)90042-E
URL : https://hal.archives-ouvertes.fr/inria-00075196
Constrained restoration and the recovery of discontinuities, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.3, pp.367-383, 1992. ,
DOI : 10.1109/34.120331
Diffeomorphic matching of distributions: a new approach for unlabelled point-sets and sub-manifolds matching, Proceedings of the 2004 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2004. CVPR 2004., pp.712-718, 2004. ,
DOI : 10.1109/CVPR.2004.1315234
Multi-scale EM-ICP: A Fast and Robust Approach for Surface Registration, European Conference on Computer Vision, pp.418-432, 2002. ,
DOI : 10.1007/3-540-47979-1_28
URL : https://hal.archives-ouvertes.fr/inria-00615911
On Use of the EM for Penalized Likelihood Estimation, Journal of the Royal Statistical Society. Series B (Methodological), vol.52, issue.3, pp.443-452, 1990. ,
The Fast Gauss Transform, SIAM Journal on Scientific and Statistical Computing, vol.12, issue.1, pp.79-94, 1991. ,
DOI : 10.1137/0912004
Feature Extraction from Point Clouds, Proceedings of the 10th International Meshing Roundtable, pp.293-305, 2001. ,
Rigid and Articulated Point Registration with Expectation Conditional Maximization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.587-602, 2010. ,
DOI : 10.1109/TPAMI.2010.94
URL : https://hal.archives-ouvertes.fr/inria-00435772
Non-Rigid Registration Under Isometric Deformations, Computer Graphics Forum, vol.26, issue.3, pp.1449-1457, 2008. ,
DOI : 10.1111/j.1467-8659.2008.01285.x
A robust algorithm for point set registration using mixture of gaussians, IEEE International Conference on Computer Vision, pp.1246-1251, 2005. ,
Landmark matching via large deformation diffeomorphisms, IEEE Transactions on Image Processing, vol.9, issue.8, pp.1357-1370, 2000. ,
DOI : 10.1109/83.855431
Surface shape and curvature scales, Image and Vision Computing, vol.10, issue.8, pp.557-564, 1992. ,
DOI : 10.1016/0262-8856(92)90076-F
Curvature guided surface registration using level sets, Congress on Computer Assisted Radiology and Surgery, 2007. ,
A survey of medical image registration, Medical Image Analysis, vol.2, issue.1, pp.1-36, 1998. ,
DOI : 10.1016/S1361-8415(01)80026-8
389: Separating Mixtures of Normal Distributions, Biometrics, vol.31, issue.3, pp.31767-769, 1975. ,
DOI : 10.2307/2529563
Articulated shape matching using Laplacian eigenfunctions and unsupervised point registration, 2008 IEEE Conference on Computer Vision and Pattern Recognition, 2008. ,
DOI : 10.1109/CVPR.2008.4587538
URL : https://hal.archives-ouvertes.fr/inria-00590251
Image registration with shape mixtures [33] A. Myronenko and X. Song. Point-Set Registration: Coherent Point Drift, Image Analysis and Processing, pp.172-1792262, 1997. ,
Non-rigid point set registration: Coherent point drift, Advances in Neural Information Processing Systems, pp.1009-1016, 2007. ,
A robust point-matching algorithm for autoradiograph alignment, Medical Image Analysis, vol.1, issue.4, pp.379-398, 1997. ,
DOI : 10.1016/S1361-8415(97)85008-6
Anatomical standardization of the human brain in euclidean 3-space and on the cortical 2-manifold, 2004. ,
Deformable Density Matching for 3D Non-rigid Registration of Shapes, Medical Image Computind anf Computer Assisted Intervention, vol.10, pp.942-951, 2007. ,
DOI : 10.1007/978-3-540-75757-3_114
Point Set Registration via Particle Filtering and Stochastic Dynamics, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.8, 2009. ,
DOI : 10.1109/TPAMI.2009.142
A Generalized Representer Theorem, Annual Conference on Computational Learning Theory, pp.416-426, 2001. ,
DOI : 10.1007/3-540-44581-1_27
Clustering Methods Based on Likelihood Ratio Criteria, Biometrics, vol.27, issue.2, pp.387-397, 1971. ,
DOI : 10.2307/2529003
An Algorithm for Associating the Features of Two Images, Proceedings of the Royal Society B: Biological Sciences, vol.244, issue.1309, pp.21-26, 1991. ,
DOI : 10.1098/rspb.1991.0045
Feature-based correspondence: an eigenvector approach, Image and Vision Computing, vol.10, issue.5, pp.283-288, 1992. ,
DOI : 10.1016/0262-8856(92)90043-3
Efficient Registration of 3D SPHARM Surfaces, Fourth Canadian Conference on Computer and Robot Vision (CRV '07), pp.81-88, 2007. ,
DOI : 10.1109/CRV.2007.26
Existence and uniqueness of minimization problems with Fourier based stabilizers, Compstat, 2004. ,
A Relationship Between Arbitrary Positive Matrices and Doubly Stochastic Matrices, The Annals of Mathematical Statistics, vol.35, issue.2, pp.876-879, 1964. ,
DOI : 10.1214/aoms/1177703591
Non-rigid Image Registration Using Graph-cuts, Medical Image Computing and Computer-Assisted Intervention, 2007. ,
DOI : 10.1007/978-3-540-75757-3_111
Image matching as a diffusion process: an analogy with Maxwell's demons, Medical Image Analysis, vol.2, issue.3, pp.243-260, 1998. ,
DOI : 10.1016/S1361-8415(98)80022-4
A Correlation-Based Approach to Robust Point Set Registration, European conference on computer vision, pp.558-569, 2004. ,
DOI : 10.1007/978-3-540-24672-5_44
Surface Matching via Currents, Proceedings of Information Processing in Medical Imaging, pp.381-392, 2005. ,
DOI : 10.1007/11505730_32
URL : https://hal.archives-ouvertes.fr/hal-00263652
Generalized L2-Divergence and Its Application to Shape Alignment, IEEE Information Processing in Medical Imaging, pp.227-238, 2009. ,
DOI : 10.1007/978-3-540-75757-3_32
Groupwise point pattern registration using a novel CDF-based Jensen-Shannon divergence, IEEE conference on Computer Vision and Pattern Recognition, pp.1283-1288, 2006. ,
A Generalized Kernel Consensus-Based Robust Estimator, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.1, pp.178-184, 2010. ,
DOI : 10.1109/TPAMI.2009.148
Statistical approaches to feature-based object recognition, International Journal of Computer Vision, vol.21, issue.1/2, pp.63-98, 1997. ,
DOI : 10.1023/A:1007923522710
Scattered Data Approximation, Cambridge Monographs on Applied and Computational Mathematics, 2005. ,
DOI : 10.1017/CBO9780511617539
Spherical Demons: Fast Diffeomorphic Landmark-Free Surface Registration, IEEE Transactions on Medical Imaging, vol.29, issue.3, pp.650-668, 2010. ,
DOI : 10.1109/TMI.2009.2030797
URL : https://hal.archives-ouvertes.fr/inria-00616102
A mathematical analysis of the motion coherence theory, International Journal of Computer Vision, vol.213, issue.2, pp.155-175, 1989. ,
DOI : 10.1007/BF00126430
Non-rigid Surface Registration Using Spherical Thin-Plate Splines, Medical Image Computing and Computer-Assisted Intervention, pp.367-374, 2007. ,
DOI : 10.1007/978-3-540-75757-3_45
