Statistical Analysis of the Global Geodesic Function for 3D Object Classification, IEEE International Conference on Acoustics, Speech and Signal Processing, vol.1, pp.645-648, 2007. ,
Theory of reproducing kernels, Transactions of the American Mathematical Society, vol.68, issue.3, pp.337-404, 1950. ,
Performance of optical flow techniques, International Journal of Computer Vision, vol.12, pp.43-77, 1994. ,
Robust and efficient estimation by minimising a density power divergence, Biometrika, vol.85, issue.3, pp.549-559, 1998. ,
Multidimensional binary search trees used for associative searching, Communications of the ACM, vol.18, issue.9, pp.509-517, 1975. ,
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
Principal warps: Thin-plate splines and the decomposition of deformations, IEEE Transaction Pattern Analysis and Machine Intelligence, vol.11, issue.6, pp.567-585, 1989. ,
Radial functions on compact support, Proceedings of the Edinburgh Mathematical Society, vol.41, issue.1, pp.33-46, 1998. ,
Geodesic interpolating splines, International Conference on Energy Minimization Methods in Computer Vision and Pattern Recognition, pp.513-527, 2001. ,
Spectral correspondence for deformed point-set matching, International Workshop on Articulated Motion and Deformable Objects, pp.120-132, 2000. ,
Group-wise point-set registration using a novel cdf-based havrdacharvát divergence, International Journal of Computer Vision, vol.86, issue.1, pp.111-124, 2009. ,
A new algorithm for non-rigid point matching, IEEE Computer Vision and Pattern Recognition, vol.2, pp.44-51, 2000. ,
A unified non-rigid feature registration method for brain mapping, Medical Image Analysis, vol.7, issue.2, pp.113-130, 2003. ,
Setting priors and enforcing constraints on matches for nonlinear registration of meshes, Medical Image Computing and Computer Assisted Interventions Conference, vol.5762, pp.175-183, 2009. ,
An efficient em-icp algorithm for symmetric consistent non-linear registration of point sets, Medical Image Computing and Computer-Assisted Intervention -MICCAI 2010, pp.594-601, 2010. ,
Estimating the components of a mixture of normal distributions, Biometrika, vol.56, issue.3, pp.463-474, 1969. ,
Curvature guided level set registration using adaptive finite elements, IEEE Conference on Pattern recognition, pp.527-536, 2007. ,
Maximum Likelihood from Incomplete Data via the EM Algorithm, Journal of the Royal Statistical Society. Series B (Methodological), vol.39, issue.1, pp.1-38, 1977. ,
Rigid, affine and locally affine registration of free-form surfaces, International Journal of Computer Vision, vol.18, issue.2, pp.99-119, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00074451
A classification EM algorithm for clustering and two stochastic versions, Computational Statistics and Data Analysis, vol.14, issue.3, pp.315-332, 1992. ,
URL : https://hal.archives-ouvertes.fr/inria-00075196
Constrained restoration and the recovery of discontinuities, IEEE Transaction on Pattern Analysis and Machine Intelligence, vol.14, issue.3, pp.367-383, 1992. ,
Regularization theory and neural networks architectures, Neural Computation, vol.7, issue.2, pp.219-269, 1995. ,
Diffeomorphic matching of distributions: A new approach for unlabelled point-sets and sub-manifolds matching, IEEE Conference on Computer Vision and Pattern Recognition, pp.712-718, 2004. ,
Multi-scale EM-ICP: A fast and robust approach for surface registration, European Conference on Computer Vision, vol.2353, pp.418-432, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00615911
On Use of the EM for Penalized Likelihood Estimation, Journal of the Royal Statistical Society. Series B (Methodological), vol.52, issue.3, pp.443-452, 1990. ,
The fast Gauss transform, SIAM Journal of Sci. Stat. Comput, vol.12, issue.1, pp.79-94, 1991. ,
Feature Extraction from Point Clouds, 10th International Meshing Roundtable, pp.293-305, 2001. ,
Diffeomorphic point matching with applications in biomedical image registration, International Journal of Tomography and Statistics, vol.15, issue.F10, 2009. ,
Robust point set registration using em-icp with information-theoretically optimal outlier handling, IEEE Conference on Computer Vision and Pattern Recognition, pp.2465-2472, 2011. ,
Rigid and articulated point registration with expectation conditional maximization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.587-602, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00435772
Non-rigid registration under isometric deformations, Computer Graphics Forum, vol.27, issue.5, pp.1449-1457, 2008. ,
Generation of a statistical shape model with probabilistic point correspondences and the expectation maximization-iterative closest point algorithm, International Journal of Computer Assisted Radiology and Surgery, vol.2, issue.5, pp.265-273, 2008. ,
A robust algorithm for point set registration using mixture of Gaussians, IEEE International Conference on Computer Vision, vol.2, pp.1246-1251, 2005. ,
Landmark matching via large deformation diffeomorphisms, IEEE Transactions on Image Processing, vol.9, issue.8, pp.1357-1370, 2000. ,
Surface shape and curvature scales, Image and Vision Computing, vol.10, issue.8, pp.557-564, 1992. ,
Curvature guided surface registration using level sets, Congress on Computer Assisted Radiology and Surgery, 2007. ,
Robust estimation of nonrigid transformation for point set registration, 2013 IEEE Conference on Computer Vision and Pattern Recognition, pp.2147-2154, 2013. ,
A survey of medical image registration, Medical Image Analysis, vol.2, issue.1, pp.1-36, 1998. ,
Recent developments and trends in point set registration methods, Journal of Visual Communication and Image Representation, vol.46, pp.95-101, 2017. ,
Separating Mixtures of Normal Distributions, Biometrics, vol.31, issue.3, pp.767-769, 1975. ,
Articulated shape matching using Laplacian eigenfunctions and unsupervised point registration, IEEE Conference on Computer Vision and Pattern Recognition, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00590251
Image registration with shape mixtures, International Conference on Image Analysis and Processing, vol.1311, pp.172-179, 1997. ,
Point-Set Registration: Coherent Point Drift, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.12, pp.2262-2275, 2010. ,
Multiple kernel point set registration, IEEE Transactions on Medical Imaging, vol.35, issue.6, pp.1381-1394, 2016. ,
A robust point-matching algorithm for autoradiograph alignment, Medical Image Analysis, vol.1, issue.4, pp.379-398, 1997. ,
Anatomical standardization of the human brain in euclidean 3-space and on the cortical 2-manifold, 2004. ,
Deformable density matching for 3D non-rigid registration of shapes, In Medical Image Computing and Computer Assisted Intervention, vol.4791, pp.942-949, 2007. ,
Point set registration via particle filtering and stochastic dynamics, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.99, 2009. ,
A generalized representer theorem, Proceedings of the Annual Conference on Computational Learning Theory, pp.416-426, 2001. ,
Clustering Methods Based on Likelihood Ratio Criteria, Biometrics, vol.27, issue.2, pp.387-397, 1971. ,
An algorithm for associating the features of two images, Proceedings: Biological Sciences, vol.244, pp.21-26, 1309. ,
Feature-based correspondence: an eigenvector approach, Image and Vision Computing, vol.10, issue.5, pp.283-288, 1992. ,
Efficient Registration of 3D SPHARM Surfaces. Canadian Conference on Computer and Robot Vision, pp.81-88, 2007. ,
A relationship between arbitrary positive matrices and doubly stochastic matrices, The Annals of Mathematical Statistics, vol.35, issue.2, pp.876-879, 1964. ,
Registration of 3d point clouds and meshes: A survey from rigid to nonrigid, IEEE Transactions on Visualization and Computer Graphics, vol.19, issue.7, pp.1199-1217, 2013. ,
Spectral correspondence using local similarity analysis, 2007 International Conference on Computational Intelligence and Security (CIS 2007), pp.395-399, 2007. ,
Asymmetrical gauss mixture models for point sets matching, IEEE Conference on Computer Vision and Pattern Recognition, pp.1598-1605, 2014. ,
Image matching as a diffusion process: an analogy with Maxwell's demons, Medical Image Analysis, vol.2, issue.3, pp.243-260, 1998. ,
A correlation-based approach to robust point set registration, European conference on computer vision, vol.3, pp.558-569, 2004. ,
Point Set Registration Using Havrda-Charvat-Tsallis Entropy Measures, IEEE Transactions on Medical Imaging, vol.30, issue.2, pp.451-460, 2011. ,
Surface matching via currents, Proceedings of Information Processing in Medical Imaging, pp.381-392, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00263652
Existence and uniqueness of minimization problems with fourier based stabilizers, COMPSTAT 2004 -Proceedings in Computational Statistics, pp.1853-1860, 2004. ,
Generalized L2-Divergence and its application to shape alignment, IEEE Information Processing in Medical Imaging, pp.227-238, 2009. ,
Groupwise point pattern registration using a novel CDF-based Jensen-Shannon divergence, IEEE conference on Computer Vision and Pattern Recognition, pp.1283-1288, 2006. ,
Simultaneous nonrigid registration of multiple point sets and atlas construction, IEEE Transactions on Pattern Analysis Machine Intelligence, vol.30, issue.11, pp.2011-2022, 2008. ,
A generalized kernel consensus-based robust estimator, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, pp.178-184, 2010. ,
Statistical approaches to feature-based object recognition, International Journal of Computer Vision, vol.21, issue.1-2, pp.63-98, 1997. ,
Scattered Data Approximation, Cambridge Monographs on Applied and Computational Mathematics, 2004. ,
Spherical demons: Fast diffeomorphic landmark-free surface registration, IEEE Transactions on Medical Imaging, vol.29, issue.3, pp.650-668, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00616102
Deformation analysis for shape and image processing, 2001. ,
A mathematical analysis of the motion coherence theory, International Journal of Computer Vision, vol.3, issue.2, pp.155-175, 1989. ,
Non-rigid surface registration using spherical Thin-Plate splines, In Medical Image Computing and Computer-Assisted Intervention, pp.367-374, 2007. ,
