Signaling Environment for Service Level Negotiation and QoS management in Mobile IP Networks
Abstract : This paper describes a signaling environment for service level negotiation and advance resource reservation in mobile IP networks. This environment is built in conformance with the generic signaling environment, which is standardized by the NSIS IETF working group. The service level negotiation protocol, called SLN NSLP, integrates the NSIS architecture to assure, thanks to the negotiation of an SLS, the availability of the resources needed by applications. The advance resource reservation protocol, called MQoS NSLP, is based on the QoS NSLP signaling application. It provides to mobile terminals the QoS required by taken into account the user's mobility and QoS profile. The advance resource reservation is based on an object MSpec (Mobility Specification) which determines the future location of the mobile terminal. The MSpec object which is a part of a mobility and QoS profile, is determined by the mobile terminal.
Type de document :
Communication dans un congrès
14th International Conference on Telecommunication Systems - Modeling and Analysis (ICTSM2006), Oct 2006, Pennsylvania, United States. 2006
Liste complète des métadonnées
Littérature citée [2 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-00657680
Contributeur : Badr Benmammar <>
Soumis le : lundi 9 janvier 2012 - 15:34:57
Dernière modification le : jeudi 11 janvier 2018 - 06:20:16
Document(s) archivé(s) le : lundi 19 novembre 2012 - 12:56:30
Fichier
ICTSM2006-Badr.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00657680, version 1
Collections
Citation
Badr Benmammar, Nader Mbarek, Francine Krief. Signaling Environment for Service Level Negotiation and QoS management in Mobile IP Networks. 14th International Conference on Telecommunication Systems - Modeling and Analysis (ICTSM2006), Oct 2006, Pennsylvania, United States. 2006. 〈hal-00657680〉
Métriques
Consultations de la notice
182
Téléchargements de fichiers
77
