BLIND CALIBRATION FOR COMPRESSED SENSING BY CONVEX OPTIMIZATION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of calibrating a compressed sensing measurement system under the assumption that the decalibration consists in unknown gains on each measure. We focus on blind calibration, using measures performed on a few unknown (but sparse) signals. A naive formulation of this blind calibration problem, using l1 minimization, is reminiscent of blind source separation and dictionary learning, which are known to be highly non-convex and riddled with local minima. In the considered context, we show that in fact this formulation can be exactly expressed as a convex optimization problem, and can be solved using off-the-shelf algorithms. Numerical simulations demonstrate the effectiveness of the approach even for highly uncalibrated measures, when a sufficient number of (unknown, but sparse) calibrating signals is provided. We observe that the success/failure of the approach seems to obey sharp phase transitions.
Calibration_rev.pdf (190.67 Ko) Télécharger le fichier
hal-00658579 , version 1 (11-01-2012)
hal-00658579 , version 2 (19-01-2012)
  • HAL Id : hal-00658579 , version 1
Rémi Gribonval, Gilles Chardon, Laurent Daudet. BLIND CALIBRATION FOR COMPRESSED SENSING BY CONVEX OPTIMIZATION. IEEE International Conference on Acoustics, Speech, and Signal Processing, Mar 2012, Kyoto, Japan. ⟨hal-00658579v1⟩
822 Consultations
683 Téléchargements
