Blind Calibration For Compressed Sensing By Convex Optimization - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
(1) , (2) , (2)
1
2
We consider the problem of calibrating a compressed sensing measurement system under the assumption that the decalibration consists in unknown gains on each measure. We focus on blind calibration, using measures performed on a few unknown (but sparse) signals. A naive formulation of this blind calibration problem, using l1 minimization, is reminiscent of blind source separation and dictionary learning, which are known to be highly non-convex and riddled with local minima. In the considered context, we show that in fact this formulation can be exactly expressed as a convex optimization problem, and can be solved using off-the-shelf algorithms. Numerical simulations demonstrate the effectiveness of the approach even for highly uncalibrated measures, when a sufficient number of (unknown, but sparse) calibrating signals is provided. We observe that the success/failure of the approach seems to obey sharp phase transitions.
Calibration_hal.pdf (456.86 Ko) Télécharger le fichier
Dates and versions
hal-00658579 , version 1 (11-01-2012)
hal-00658579 , version 2 (19-01-2012)
Identifiers
  • HAL Id : hal-00658579 , version 2
Cite
Rémi Gribonval, Gilles Chardon, Laurent Daudet. Blind Calibration For Compressed Sensing By Convex Optimization . IEEE International Conference on Acoustics, Speech, and Signal Processing, Mar 2012, Kyoto, Japan. ⟨hal-00658579v2⟩
743 View
648 Download
Share
