Scalable and Secure Aggregation in Distributed Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We consider the problem of computing an aggregation function in a \emph{secure} and \emph{scalable} way. Whereas previous distributed solutions with similar security guarantees have a communication cost of $O(n^3)$, we present a distributed protocol that requires only a communication complexity of $O(n\log^3 n)$, which we prove is near-optimal. Our protocol ensures perfect security against a computationally-bounded adversary, tolerates $(1/2-\epsilon)n$ malicious nodes for any constant $1/2 > \epsilon > 0$ (not depending on $n$), and outputs the exact value of the aggregated function with high probability.
hal-00660056 , version 1 (15-01-2012)
Sebastien Gambs, Rachid Guerraoui, Hamza Harkous, Florian Huc, Anne-Marie Kermarrec. Scalable and Secure Aggregation in Distributed Networks. 2011. ⟨hal-00660056⟩
662 Consultations
0 Téléchargements
