An optimal quantum algorithm to approximate the mean and its application for approximating the median of a set of points over an arbitrary distance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We describe two quantum algorithms to approximate the mean value of a black-box function. The first algorithm is novel and asymptotically optimal while the second is a variation on an earlier algorithm due to Aharonov. Both algorithms have their own strengths and caveats and may be relevant in different contexts. We then propose a new algorithm for approximating the median of a set of points over an arbitrary distance function.
hal-00660058 , version 1 (15-01-2012)
Gilles Brassard, Frederic Dupuis, Sebastien Gambs, Alain Tapp. An optimal quantum algorithm to approximate the mean and its application for approximating the median of a set of points over an arbitrary distance. 2011. ⟨hal-00660058⟩
247 Consultations
0 Téléchargements
