On smooth time functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Proceedings of the Cambridge Philosophical Society Année : 2011
We are concerned with the existence of smooth time functions on connected time{oriented Lorentzian manifolds. The problem is tackled in a more general abstract setting, namely in a manifold M where is just de ned a eld of tangent convex cones (Cx)x2M enjoying mild continuity properties. Under some conditions on its integral curves, we will construct a time function. Our approach is based on the de nition of an intrinsic length for curves indicating how a curve is far from being an integral trajectory of Cx. We nd connections with topics pertaining to Hamilton{Jacobi equations, and make use of tools and results issued from weak KAM theory.
FathiSiconolfi11.pdf (376.39 Ko) Télécharger le fichier
hal-00660452 , version 1 (16-01-2012)
Albert Fathi, Antonio Siconolfi. On smooth time functions. Mathematical Proceedings of the Cambridge Philosophical Society, 2011, ⟨10.1017/S0305004111000661⟩. ⟨hal-00660452⟩
146 Consultations
381 Téléchargements
