Preprints, Working Papers, ...
Optimal Power Division Among Different User Speed Classes in Small Cell Networks
Veeraruna Kavitha Voleti 1 Veronique Capdevielle 2, *
* Corresponding author
1 MAESTRO - Models for the performance analysis and the control of networks
CRISAM - Inria Sophia Antipolis - Méditerranée
2 Alcatel Lucent Bell Labs
Abstract : Small cell networks promise to boost the capacity and provide good QoS (Quality of Service) to cell edge users. However they pose serious challenges, especially in the case of high speed unidirectional (e.g., users traveling in high ways or in metros) users, in the form of frequent handovers. The extent of the handover losses depends greatly upon the speed of the user and we showed in our previous paper that optimal cell size increases with speed. Thus in scenarios with diverse users (speeds spanning over large ranges), it would be inefficient to serve all of them using common cell radius and it is practically infeasible to design different cell sizes to different speeds. We alternatively propose to allocate power to an user based on its speed. Higher power virtually increases the cell size. We provide an optimal power division (which optimizes an appropriate QoS that considers handover losses), for any given power budget and cell size. We further establish the need for higher power budgets for higher cell sizes, which we called as beta+ power scaling (beta is pathloss factor). We finally obtain optimal cell size, after beta+ scaling and optimal power division.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-00660618
Contributor : Veeraruna Kavitha Voleti Connect in order to contact the contributor
Submitted on : Wednesday, January 18, 2012 - 11:43:31 AM
Last modification on : Tuesday, January 9, 2018 - 10:50:02 AM
Long-term archiving on: : Thursday, April 19, 2012 - 2:23:19 AM
File
WiOptPowerLaw.pdf
Identifiers
  • HAL Id : hal-00660618, version 2
Citation
Veeraruna Kavitha Voleti, Veronique Capdevielle. Optimal Power Division Among Different User Speed Classes in Small Cell Networks. 2012. ⟨hal-00660618v2⟩
Share
