New interface
Conference papers
Noise Aware Analysis Operator Learning For Approximately Cosparse Signals
Abstract : This paper investigates analysis operator learning for the recently introduced cosparse signal model that is a natural analysis complement to the more traditional sparse signal model. Previous work on such analysis operator learning has relied on access to a set of clean training samples. Here we introduce a new learning framework which can use training data which is corrupted by noise and/or is only approximately cosparse. The new model assumes that a p-cosparse signal exists in an epsilon neighborhood of each data point. The operator is assumed to be uniformly normalized tight frame (UNTF) to exclude some trivial operators. In this setting, an alternating optimization algorithm is introduced to learn a suitable analysis operator.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-00661549
Contributor : Rémi Gribonval Connect in order to contact the contributor
Submitted on : Thursday, January 19, 2012 - 9:18:35 PM
Last modification on : Friday, February 4, 2022 - 3:09:20 AM
Long-term archiving on: : Friday, April 20, 2012 - 2:33:03 AM
File
icassp12_v2.pdf
Identifiers
Citation
Mehrdad Yaghoobi, Sangnam Nam, Rémi Gribonval, Michael E. Davies. Noise Aware Analysis Operator Learning For Approximately Cosparse Signals . ICASSP - IEEE International Conference on Acoustics, Speech, and Signal Processing - 2012, Mar 2012, Kyoto, Japan. ⟨10.1109/ICASSP.2012.6289144⟩. ⟨hal-00661549⟩
Share
Metrics
Record views
309
Files downloads
361
