Abstract : In order to bulletproof the P2P-RPL specification currently in the works, interoper- ability testing of two independent implementations have been carried out. This document reports the tests that were performed and the bugs that were detected in the specification and their fixing. The updated P2P-RPL specification taking into account this bulletproofing was then published.
Résumé : Ce document rapporte les résultats de tests d'interopérabilité du protocole de routage P2P-RPL pour réseaux de capteurs.
