A nested cortex parcellation combining analysis of MEG forward problem and diffusion MRI tractography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Understanding the relationship between structure and function is a major challenge in neuroscience. Diffusion MRI (dMRI) in the only non-invasive modality allowing to have access to the neural structure. Magnetoencephalography (MEG) is another non-invasive modality that allows a direct access to the temporal succession of cognitive processes. Functional cortex parcellation being one of the most impor- tant ways to understanding structure-function relationship, we propose an innovative method merging MEG and dMRI to parcellate the cortex. The combination of MEG forward problem and connectivity information reveals cortical areas generating a similar magnetic field at sensors while having a similar connectivity. Results show suitable clusters that forecast interesting studies for inter- and intra- subjects com- parisons of the cortex parcellations. The automatic nested cortex parcellation we propose could be a first step to analyse sources that are seeds of long or short range connectivity and to differentiate these connectivities in the white matter.
Neurosciences
PHILIPPE_Ac_ISBI12.pdf (230.27 Ko) Télécharger le fichier
hal-00662776 , version 1 (25-01-2012)
  • HAL Id : hal-00662776 , version 1
Anne-Charlotte Philippe, Maureen Clerc, Théodore Papadopoulo, Rachid Deriche. A nested cortex parcellation combining analysis of MEG forward problem and diffusion MRI tractography. ISBI - IEEE International Symposium on Biomedical Imaging - 2012, May 2012, Barcelona, Spain. ⟨hal-00662776⟩
239 Consultations
225 Téléchargements
