Deembedding of filters' responses from diplexer measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a method capable of computing the characteristic polynomials of two filters embedded in a diplexer for which a set of measured external scattering parameters is given. Such a method works under general hypotheses without particular assumptions on the junction or the loss-less nature of the filters. The technique is based on a polynomial approximation scheme derived in an analytic manner from the algebraic structure of the diplexer's response. The presented procedure is typically meant as a deembeding step, eventually yielding the coupling matrices of the two filters that can be used during the tuning process of the diplexer.
Fichier non déposé
hal-00663515 , version 1 (27-01-2012)
Matteo Oldoni, Fabien Seyfert, Giuseppe Macchiarella, Damien Pacaud. Deembedding of filters' responses from diplexer measurements. Microwave Symposium Digest (MTT), 2011 IEEE MTT-S International, 2011, Baltimore, United States. pp.1 -4, ⟨10.1109/MWSYM.2011.5972691⟩. ⟨hal-00663515⟩
Collections
INRIA INRIA2
85 Consultations
0 Téléchargements
