Conference papers
Simplified design of microwave filters with asymmetric transfer functions
Abstract : This paper presents the design of a microwave bandpass filter having an asymmetric transfer function and a symmetric geometry. The purpose is to demonstrate that an efficient synthesis can provide simpler solutions for the hardware implementation. An example of a 6th order dual mode filter in circular waveguide technology is presented. Considering the desired topology, the initial synthesis from the Chebyshev transfer function leads to two solutions with an asymmetric electrical network. A symmetric network is then synthesised increasing the number of couplings. For one of the solutions, weak couplings can be neglected so that the transfer function is only slightly affected. The modified symmetric electrical network leads then to a simpler hardware implementation of the dual mode filter. The electrical network synthesis is described, then the optimal geometrical dimensions of the filter are determined applying an electromagnetic based optimisation method. An experimental realisation is finally compared to the theoretical results.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00663524
Contributor : Fabien Seyfert Connect in order to contact the contributor
Submitted on : Friday, January 27, 2012 - 12:58:39 PM
Last modification on : Saturday, June 25, 2022 - 11:07:33 PM
Identifiers
Collections
Citation
Stéphane Bila, Dominique Baillargeat, Serge Verdeyme, Fabien Seyfert, Laurent Baratchart, et al.. Simplified design of microwave filters with asymmetric transfer functions. Microwave Conference, 2003. 33rd European, 2003, Munich, Germany. pp.1357 -1360, ⟨10.1109/EUMA.2003.340872⟩. ⟨hal-00663524⟩
Share
Metrics
Record views
100
