Dynamic Bayesian networks for symbolic polyphonic pitch modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stanislaw Andrzej Raczynski
  • Fonction : Auteur
  • PersonId : 891100
Shigeki Sagayama
  • Fonction : Auteur
  • PersonId : 835791
The performance of many MIR analysis algorithms, most importantly polyphonic pitch transcription, can be improved by introducing musicological knowledge to the estimation process. We have developed a probabilistically rigorous musicological model that takes into account dependencies between consequent musical notes and consequent chords, as well as the dependencies between chords, notes and the observed note saliences. We investigate its modeling potential by measuring and comparing the cross-entropy with symbolic (MIDI) data.
raczynski_SIGMUS11.pdf (419.25 Ko) Télécharger le fichier
hal-00663954 , version 1 (27-01-2012)
  • HAL Id : hal-00663954 , version 1
Stanislaw Andrzej Raczynski, Emmanuel Vincent, Shigeki Sagayama. Dynamic Bayesian networks for symbolic polyphonic pitch modeling. 91st IPSJ Special Interest Group on MUSic and computer (SIGMUS) Meeting, Jul 2011, Ibaraki, Japan. pp.no. 8. ⟨hal-00663954⟩
191 Consultations
205 Téléchargements
