Specification of the CHOReOS IDRE (D5.2) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Amira Ben Hamida
  • Fonction : Auteur
  • PersonId : 900047
James Lockerbie
  • Fonction : Auteur
  • PersonId : 909479
Animesh Pathak
Pierre Châtel
Marco Autili
  • Fonction : Auteur
  • PersonId : 854161
Massimo Tivoli
  • Fonction : Auteur
  • PersonId : 861036
Davide Di Ruscio
  • Fonction : Auteur
  • PersonId : 863561
Felipe Besson
  • Fonction : Auteur
  • PersonId : 892462
Gustavo Oliva
  • Fonction : Auteur
  • PersonId : 913261
This deliverable focuses on the design of the CHOReOS Integrated Development and Runtime Environment, aka CHOReOS IDRE, based on the supporting solutions developed within WP2, WP3 and WP4 during CHOReOS' 1st year. The document provides an overall description of the IDRE components, their respective functionalities and the integration dependencies between them, thereby defining the integration points between the components developed in WP2-3-4.
CHOReOSWP5D5.2SpecificationoftheCHOReOSIDREVA.pdf (2.59 Mo) Télécharger le fichier
hal-00664305 , version 1 (02-02-2012)
  • HAL Id : hal-00664305 , version 1
Amira Ben Hamida, James Lockerbie, Antonia Bertolino, Guglielmo De Angelis, Nikolaos Georgantas, et al.. Specification of the CHOReOS IDRE (D5.2). 2011. ⟨hal-00664305⟩
273 Consultations
592 Téléchargements
