Local search in combinatorial optimization, 1997. ,
Fine-Tuning of Algorithms Using Fractional Experimental Designs and Local Search, Operations Research, vol.54, issue.1, pp.99-114, 2006. ,
DOI : 10.1287/opre.1050.0243
MALLBA: A Library of Skeletons for Combinatorial Optimisation, Parallel Processing Conference (Euro-Par 2002), pp.927-932, 2002. ,
DOI : 10.1007/3-540-45706-2_132
Fitness distance correlation analysis: an instructive counterexemple, Seventh Int. Conf. on Genetic Algorithms, pp.57-64, 1997. ,
Statistical Properties of Neutral Evolution, Journal of Molecular Evolution, vol.57, issue.0, pp.103-119, 2003. ,
DOI : 10.1007/s00239-003-0013-4
LocalSolver 1.x: a black-box local-search solver for 0-1 programming, 4OR, vol.20, issue.2, pp.299-316, 2011. ,
DOI : 10.1007/s10288-011-0165-9
A racing algorithm for configuring metaheuristics, Proceedings of the Genetic and Evolutionary Computation Conference, pp.11-18, 2002. ,
PISA ??? A Platform and Programming Language Independent Interface for Search Algorithms, Second International Conference on Evolutionary Multi-Criterion Optimization, pp.494-508, 2003. ,
DOI : 10.1007/3-540-36970-8_35
Metaheuristics based de novo protein sequencing: A new approach, Applied Soft Computing, vol.11, issue.2, pp.2271-2278, 2011. ,
DOI : 10.1016/j.asoc.2010.08.007
URL : https://hal.archives-ouvertes.fr/inria-00575764
Enhancing Timetable Solutions with Local Search Methods, Practise and Theory of Automated Timetabling IV (PATAT 2002, pp.195-206, 2002. ,
DOI : 10.1007/978-3-540-45157-0_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.7546
ParadisEO: A Framework for the Reusable Design of Parallel and Distributed Metaheuristics, Journal of Heuristics, vol.10, issue.3, pp.357-380, 2004. ,
DOI : 10.1023/B:HEUR.0000026900.92269.ec
Thermodynamical approach to the traveling salesman problem: An efficient simulation algorithm, Journal of Optimization Theory and Applications, vol.21, issue.1, pp.41-51, 1985. ,
DOI : 10.1007/BF00940812
The noising method: a new method for combinatorial optimization, Operations Research Letters, vol.14, issue.3, pp.133-137, 1993. ,
DOI : 10.1016/0167-6377(93)90023-A
GA-hard functions built by combination of Trap functions, Proceedings of the 2002 Congress on Evolutionary Computation. CEC'02 (Cat. No.02TH8600), pp.249-254, 2002. ,
DOI : 10.1109/CEC.2002.1006242
URL : https://hal.archives-ouvertes.fr/hal-00166375
Local Optima Networks of the Quadratic Assignment Problem, IEEE Congress on Evolutionary Computation, pp.3145-3152, 2010. ,
DOI : 10.1109/CEC.2010.5586481
URL : https://hal.archives-ouvertes.fr/hal-00487806
Global optimization and simulated annealing, Mathematical Programming, vol.56, issue.1-3, pp.367-393, 1991. ,
DOI : 10.1007/BF01594945
EasyAnalyzer: An Object-Oriented Framework for the Experimental Analysis of Stochastic Local Search Algorithms, International conference on Engineering stochastic local search algorithms, pp.76-90, 2007. ,
DOI : 10.1007/978-3-540-74446-7_6
Parameter control in evolutionary algorithms (eds) Parameter Setting in Evolutionary Algorithms, Studies in Computational Intelligence, vol.54, pp.19-46, 2007. ,
A probabilistic heuristic for a computationally difficult set covering problem, Operations Research Letters, vol.8, issue.2, pp.67-71, 1989. ,
DOI : 10.1016/0167-6377(89)90002-3
Greedy Randomized Adaptive Search Procedures, Journal of Global Optimization, vol.68, issue.2, pp.109-133, 1995. ,
DOI : 10.1007/BF01096763
EASYLOCAL++: an object-oriented framework for the flexible design of local-search algorithms, Software: Practice and Experience, vol.20, issue.8, pp.733-765, 2003. ,
DOI : 10.1002/spe.524
Future paths for integer programming and links to artificial intelligence, Computers & Operations Research, vol.13, issue.5, pp.533-549, 1986. ,
DOI : 10.1016/0305-0548(86)90048-1
The general employee scheduling problem. An integration of MS and AI, Computers & Operations Research, vol.13, issue.5, pp.563-573, 1986. ,
DOI : 10.1016/0305-0548(86)90050-X
Efficient local search with search space smoothing: a case study of the traveling salesman problem, IEEE Transactions on Systems Man and Cybernetics, vol.24, issue.5, pp.728-735, 1994. ,
An Integrated White+Black Box Approach for Designing and Tuning Stochastic Local Search, 13th International Conference on Principles and Practice of Constraint Programming, pp.332-347, 2007. ,
DOI : 10.1007/978-3-540-74970-7_25
The steepest ascent mildest descent heuristic for combinatorial programming, congress on Numerical Methods in Combinatorial Optimization, 1986. ,
Semi-greedy heuristics: An empirical study, Operations Research Letters, vol.6, issue.3, pp.107-114, 1987. ,
DOI : 10.1016/0167-6377(87)90021-6
Stochastic Local Search, 2004. ,
DOI : 10.1201/9781420010749.ch19
Programming by optimization, Communications of the ACM, vol.55, issue.2, pp.70-80, 2012. ,
DOI : 10.1145/2076450.2076469
ParamILS: an automatic algorithm configuration framework, J Artif Int Res, vol.36, issue.1, pp.267-306, 2009. ,
Local optimization and the travelling salesman problem, 17th Colloquium on Automata, Languages and Programming, pp.446-461, 1990. ,
A object-oriented framework for the implementation of search techniques, 2000. ,
Templar: A object-oriented framework for distributed combinatorial optimization, Proc. of the UNICOM Seminar on Modern Heuristics for Decision Support, 1998. ,
Evolutionary algorithms, fitness landscapes and search, 1995. ,
Evolving Objects: A General Purpose Evolutionary Computation Library, 5th International Conference on Artificial Evolution, pp.231-244, 2001. ,
DOI : 10.1007/3-540-46033-0_19
The min-conflict packing problem, Computers & Operations Research, vol.39, issue.9, pp.2122-2132, 2012. ,
DOI : 10.1016/j.cor.2011.10.021
URL : https://hal.archives-ouvertes.fr/hal-00638177
The Neutral Theory of Molecular Evolution, 1983. ,
Optimization by Simulated Annealing, Science, vol.220, issue.4598, pp.671-680, 1983. ,
DOI : 10.1126/science.220.4598.671
MAFRA: A Java memetic algorithms framework In: Data mining with evolutionary algorithms, pp.125-131, 2000. ,
Exploiting grid computation for solving the Vehicle Routing Problem, ACS/IEEE International Conference on Computer Systems and Applications, AICCSA 2010, pp.1-6, 2010. ,
DOI : 10.1109/AICCSA.2010.5587020
A software framework based on a conceptual unified model for evolutionary multiobjective optimization: ParadisEO-MOEO, European Journal of Operational Research, vol.209, issue.2, pp.104-112, 2011. ,
DOI : 10.1016/j.ejor.2010.07.023
URL : https://hal.archives-ouvertes.fr/hal-00522612
On dominance-based multiobjective local search: design, implementation and experimental analysis on scheduling and traveling salesman problems, Journal of Heuristics, vol.7, issue.2, pp.317-352, 2012. ,
DOI : 10.1007/s10732-011-9181-3
URL : https://hal.archives-ouvertes.fr/hal-00628215
Simulated Annealing Algorithms for Continuous Global Optimization: Convergence Conditions, Journal of Optimization Theory and Applications, vol.47, issue.1, pp.87-102, 2000. ,
DOI : 10.1023/A:1004680806815
Handbook of metaheuristics, Operations Research and Management Science, vol.57, pp.321-353, 2002. ,
Opt4J -A Modular Framework for Metaheuristic Optimization, Proceedings of the Genetic and Evolutionary Computing Conference, 2011. ,
Lectures on Monte Carlo Methods, 2002. ,
DOI : 10.1090/fim/016
NILS: A Neutrality-Based Iterated Local Search and Its Application to Flowshop Scheduling, Evolutionary Computation in Combinatorial Optimization Lecture Notes in Computer Science, vol.6622, pp.191-202, 2011. ,
DOI : 10.1007/978-3-642-20364-0_17
URL : https://hal.archives-ouvertes.fr/hal-00563459
On the Neutrality of Flowshop Scheduling Fitness Landscapes, 5th Learning and Intelligent OptimizatioN Conference, pp.238-252, 2011. ,
DOI : 10.1007/BF00202749
URL : https://hal.archives-ouvertes.fr/hal-00550356
Automatic design of hybrid stochastic local search metaheuristics, In: Hybrid Metaheuristics Lecture Notes in Computer Science, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01094695
Large-step markov chains for the traveling salesman problem, Complex Systems, vol.5, issue.3, pp.299-326, 1991. ,
Towards ParadisEO-MO-GPU: A Framework for GPU-Based Local Search Metaheuristics, 11th International Work-Conference on Artificial Neural Networks, 2011. ,
DOI : 10.1007/978-3-642-21501-8_50
URL : https://hal.archives-ouvertes.fr/inria-00638809
Localizer++: An open library for local search, 2001. ,
Parallel and distributed local search in COMET, Computers & Operations Research, vol.36, issue.8, pp.2357-2375, 2009. ,
DOI : 10.1016/j.cor.2008.08.014
Variable neighborhood search, Computers & Operations Research, vol.24, issue.11, pp.1097-1100, 1997. ,
DOI : 10.1016/S0305-0548(97)00031-2
URL : https://hal.archives-ouvertes.fr/hal-00979295
Efficient relevance estimation and value calibration of evolutionary algorithm parameters, 2007 IEEE Congress on Evolutionary Computation, pp.975-980, 2007. ,
DOI : 10.1109/CEC.2007.4424460
A study of NK landscapes' basins and local optima networks, Proceedings of the 10th annual conference on Genetic and evolutionary computation, GECCO '08, pp.555-562, 2008. ,
DOI : 10.1145/1389095.1389204
URL : https://hal.archives-ouvertes.fr/hal-00331868
First-Improvement vs. Best-Improvement Local Optima Networks of NK Landscapes, Proceedings of the 11th International Conference on Parallel Problem Solving From Nature, pp.104-113, 2010. ,
DOI : 10.1007/978-3-642-15844-5_11
URL : https://hal.archives-ouvertes.fr/hal-00488401
Experiments with new stochastic global optimization search techniques, Computers & Operations Research, vol.27, issue.9, pp.841-865, 2000. ,
DOI : 10.1016/S0305-0548(99)00054-4
Combinatorial optimization: algorithms and complexity, 1982. ,
Metaheuristic optimization frameworks: a survey and benchmarking, Soft Computing, vol.3, issue.4, pp.527-561, 2012. ,
DOI : 10.1007/s00500-011-0754-8
Fitness distance correlation and Ridge functions, Fifth Conference on Parallel Problems Solving from Nature (PPSN'98), pp.77-86, 1998. ,
DOI : 10.1007/BFb0056851
Neutrality in fitness landscapes, Applied Mathematics and Computation, vol.117, issue.2-3, pp.321-350, 2001. ,
DOI : 10.1016/S0096-3003(99)00166-6
An effective two-stage simulated annealing algorithm for the minimum linear arrangement problem, Computers & Operations Research, vol.35, issue.10, pp.3331-3346, 2008. ,
DOI : 10.1016/j.cor.2007.03.001
The density of states ??? A measure of the difficulty of optimisation problems, Parallel Problem Solving from Nature, pp.208-217, 1996. ,
DOI : 10.1007/3-540-61723-X_985
Representations for genetic and evolutionary algorithms, 2006. ,
DOI : 10.1007/978-3-642-88094-0
A condition for the genotype-phenotype mapping: Causality, Proc. of the 7th Int. Conf. on Genetic Algorithms, pp.73-80, 1997. ,
Fitness landscapes, Lecture Notes Physics, vol.585, pp.187-207, 2002. ,
DOI : 10.1007/3-540-45692-9_10
Local search algorithms for combinatorial problems -analysis, algorithms and new applications, 1999. ,
Metaheuristics: from design to implementation, 2009. ,
DOI : 10.1002/9780470496916
URL : https://hal.archives-ouvertes.fr/hal-00750681
A parallel adaptive tabu search approach, Parallel Computing, vol.24, issue.14, pp.2003-2019, 1998. ,
DOI : 10.1016/S0167-8191(98)00086-6
Neutral evolution of mutational robustness, Proc. Nat. Acad. Sci. USA 96, pp.9716-9720, 1999. ,
DOI : 10.1073/pnas.96.17.9716
Fitness landscapes and graphs: multimodularity, ruggedness and neutrality. In: 11th annual conference companion on Genetic and evolutionary computation conference, pp.3593-3656, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00845349
Where are bottlenecks in NK fitness landscapes?, The 2003 Congress on Evolutionary Computation, 2003. CEC '03., pp.273-280, 2003. ,
DOI : 10.1109/CEC.2003.1299585
URL : https://hal.archives-ouvertes.fr/hal-00159994
Optimization software class librairies, 2002. ,
Guided local search -an illustrative example in function optimization, BT Technology Journal, vol.16, issue.3, pp.46-50, 1998. ,
DOI : 10.1023/A:1009665513140
Guided local search and its application to the traveling salesman problem, European Journal of Operational Research, vol.113, issue.2, pp.469-499, 1999. ,
DOI : 10.1016/S0377-2217(98)00099-X
Correlated and uncorrelated fitness landscapes and how to tell the difference, Biological Cybernetics, vol.1, issue.5, pp.325-336, 1990. ,
model: A tunably rugged energy landscape, Physical Review A, vol.44, issue.10, pp.6399-6413, 1991. ,
DOI : 10.1103/PhysRevA.44.6399
Software review: the ECJ toolkit, Genetic Programming and Evolvable Machines, vol.12, issue.1, pp.65-67, 2012. ,
DOI : 10.1007/s10710-011-9148-z
Adaptive Evolution on Neutral Networks, Bulletin of Mathematical Biology, vol.63, issue.4, pp.715-730, 2001. ,
DOI : 10.1006/bulm.2001.0244
11 2.4.1 Hill-Climbing Algorithm, 11 2.4.2 Escaping from Local ,
25 3.2.1 Local Search, p.27 ,
