On some expectation and derivative operators related to integral representations of random variables with respect to a PII process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Analysis and Applications Année : 2013
Given a process with independent increments $X$ (not necessarily a martingale) and a large class of square integrable r.v. $H=f(X_T)$, $f$ being the Fourier transform of a finite measure $\mu$, we provide explicit Kunita-Watanabe and Föllmer-Schweizer decompositions. The representation is expressed by means of two significant maps: the expectation and derivative operators related to the characteristics of $X$. We also provide an explicit expression for the variance optimal error when hedging the claim $H$ with underlying process $X$. Those questions are motivated by finding the solution of the celebrated problem of global and local quadratic risk minimization in mathematical finance.
QuadraticRiskPIIFeb2012.pdf (360.35 Ko) Télécharger le fichier
hal-00665852 , version 1 (02-02-2012)
Stéphane Goutte, Nadia Oudjane, Francesco Russo. On some expectation and derivative operators related to integral representations of random variables with respect to a PII process. Stochastic Analysis and Applications, 2013, 31, pp.108--141. ⟨10.1080/07362994.2013.741395⟩. ⟨hal-00665852⟩
324 Consultations
1454 Téléchargements
