New interface
Conference papers
Searching the boundaries of a modeling space to test metamodels
Juan Cadavid 1 Benoit Baudry 1 Houari Sahraoui 2
1 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
2 GEODES
DIRO - Département d'Informatique et de Recherche Opérationnelle [Montreal]
Abstract : Model-driven software development relies on metamodels to formally capture modeling spaces. Metamodels specify concepts and relationships between them in order to represent either a specific business domain model or the input and output domains for operations on models (e.g., model refinement). In all cases, a metamodel is a finite description of a possibly infinite set of models, i.e. the set of all models which structure conforms to the description specified in the metamodel. However, there is currently no systematic method to test that a metamodel captures all the correct models of the domain and no more. In this paper, we focus on the automatic selection of a set of models in the modeling space captured by a metamodel. The selected set should both cover as many representative situations as possible and be kept small as possible for further manual analysis. We use simulated annealing to select a set of models that satisfies those two objectives and report on results using two metamodels from two different domains.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-00665866
Contributor : Juan Cadavid Connect in order to contact the contributor
Submitted on : Friday, February 3, 2012 - 3:11:07 PM
Last modification on : Friday, February 4, 2022 - 3:18:32 AM
Long-term archiving on: : Wednesday, December 14, 2016 - 3:56:26 AM
File
main.pdf
Identifiers
  • HAL Id : hal-00665866, version 1
Citation
Juan Cadavid, Benoit Baudry, Houari Sahraoui. Searching the boundaries of a modeling space to test metamodels. Fifth IEEE International Conference on Software Testing, Verification and Validation, Apr 2012, Montréal, Canada. ⟨hal-00665866⟩
Share
Metrics
Record views
203
Files downloads
407
