Epidemic Live Streaming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
Epidemic algorithms have emerged as a simple, yet effective solution for disseminating live streaming contents to a large audience. Typically, the use of epidemic algorithms is motivated by the fact that they do not rely on a specific underlying structure to work, so they are very robust against network dynamics and volatility. However, the performance of these algorithms is still little understood. This chapter is intended as an introduction to epidemic live streaming. We propose some simple metrics to understand the behavior of a diffusion algorithm, and we use elementary diffusion schemes to understand the basics of the diffusion process, for both homogeneous and heterogeneous systems. The approach that we propose mixes theoretical results, when available, with empirical observations in order to give the best possible insights.
Fichier non déposé
hal-00668018 , version 1 (08-02-2012)
Diego Perino, Fabien Mathieu. Epidemic Live Streaming. Ce Zhu and Yuenan Li and Xiamu Niu. Streaming Media Architectures, Techniques, and Applications: Recent Advances, IGI Global, pp.311-336, 2010, ⟨10.4018/978-1-61692-831-5.ch013⟩. ⟨hal-00668018⟩
111 Consultations
0 Téléchargements
