On Optimizing for Epidemic Live Streaming - Archive ouverte HAL Access content directly
Conference Papers Year : 2010
(1) , (1, 2) , (1, 2)
1
2
Optimal dissemination schemes have previously been studied for peer-to-peer live streaming applications. Live streaming being a delay-sensitive application, fine tuning of dissemination parameters is crucial. In this paper, we investigate optimal sizing of chunks, the units of data exchange, and probe sets, the number peers a given node probes before transmitting chunks. Chunk size can have significant impact on diffusion rate (chunk miss ratio), diffusion delay, and overhead. The size of the probe set can also affect these metrics, primarily through the choices available for chunk dissemination. We perform extensive simulations on the so-called random-peer, latest-useful dissemination scheme. Our results show that size does matter, with the optimal size being not too small in both cases.
icc10.pdf (119.75 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-00668519 , version 1 (10-02-2012)
Identifiers
Cite
Nidhi Hegde, Fabien Mathieu, Diego Perino. On Optimizing for Epidemic Live Streaming. ICC - IEEE International Conference on Communications - 2010, May 2010, Cape Town, South Africa. pp.1 -5, ⟨10.1109/ICC.2010.5502559⟩. ⟨hal-00668519⟩
119 View
406 Download
Share
