Performance of optical flow techniques, International Journal of Computer Vision, vol.54, issue.1, pp.43-77, 1994. ,
DOI : 10.1007/BF01420984
High-Resolution 2-D Cloud-Top Advection From Geostationary Satellite Imagery, IEEE Transactions on Geoscience and Remote Sensing, vol.44, issue.12, pp.3639-3648, 2006. ,
DOI : 10.1109/TGRS.2006.881117
A three-frame algorithm for estimating two-component image motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.886-895, 1992. ,
DOI : 10.1109/34.161348
The Robust Estimation of Multiple Motions: Parametric and Piecewise-Smooth Flow Fields, Computer Vision and Image Understanding, vol.63, issue.1, pp.75-104, 1996. ,
DOI : 10.1006/cviu.1996.0006
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
DOI : 10.1109/34.990137
URL : https://hal.archives-ouvertes.fr/hal-00329724
Vortex and Source Particles for Fluid Motion Estimation, Proc. 5th Int. Conf. on Scale-Space and PDE methods in Computer Vision (Scale-Space'05), 2005. ,
DOI : 10.1007/11408031_22
URL : https://hal.archives-ouvertes.fr/hal-00386463
Theorie du mouvement non-permanent des eaux, avec application aux crues des rivieres et l'introduction des marees dans leur lit, C. R. Acad. Sc. Paris, vol.73, pp.147-154, 1871. ,
The existence of geometrical density-image transformations corresponding to object motion, Computer Vision, Graphics, and Image Processing, vol.44, issue.2, pp.155-174, 1988. ,
DOI : 10.1016/S0734-189X(88)80003-3
Meteorological structures shape description and tracking by means of BI-RME matching, IEEE Transactions on Geoscience and Remote Sensing, vol.37, issue.2, pp.1151-1161, 1999. ,
DOI : 10.1109/36.752233
Layered Estimation of Atmospheric Mesoscale Dynamics From Satellite Imagery, IEEE Transactions on Geoscience and Remote Sensing, vol.45, issue.12, pp.454087-4104, 2007. ,
DOI : 10.1109/TGRS.2007.906156
URL : https://hal.archives-ouvertes.fr/hal-00596167
Robust regression using iteratively reweighted least-squares, Communications in Statistics - Theory and Methods, vol.3, issue.9, pp.813-827, 1977. ,
DOI : 10.1214/aos/1176342503
An introduction to dynamic meteorology. Academic press, 1992. ,
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
Estimation of dense image flow fields in fluids, IEEE Transactions on Geoscience and Remote Sensing, vol.36, issue.1, pp.256-264, 1998. ,
DOI : 10.1109/36.655334
An Automated Technique for Obtaining Cloud Motion from Geosynchronous Satellite Data Using Cross Correlation, Journal of Applied Meteorology, vol.10, issue.1, pp.118-132, 1971. ,
DOI : 10.1175/1520-0450(1971)010<0118:AATFOC>2.0.CO;2
Cloud processing for meteosat second generation European Organisation for the Exploitation of Meteorological Satellites (EUMETSAT), Available at : http://www, 1999. ,
Fluid motion recovery by coupling dense and parametric motion fields, Int. Conf. on Computer, ICCV'99, pp.620-625, 1999. ,
Improved Cloud Motion Wind Vector and Altitude Assignment Using VAS, Journal of Climate and Applied Meteorology, vol.22, issue.3, pp.377-384, 1983. ,
DOI : 10.1175/1520-0450(1983)022<0377:ICMWVA>2.0.CO;2
Lowlevel cloud motion winds from Meteosat high-resolution visible imagery. Weather and Forecasting, pp.175-184, 1997. ,
Operational Cloud-Motion Winds from Meteosat Infrared Images, Journal of Applied Meteorology, vol.32, issue.7, pp.321206-1225, 1993. ,
DOI : 10.1175/1520-0450(1993)032<1206:OCMWFM>2.0.CO;2
Motion estimation and vector splines, Proceedings of IEEE Conference on Computer Vision and Pattern Recognition CVPR-94, pp.939-942, 1994. ,
DOI : 10.1109/CVPR.1994.323929
Using multiple channels from MSG to improve atmospheric motion wind selection and quality, 7th International Winds Workshop, EUMETSAT EUM P 42, pp.307-314, 2004. ,
Discrete orthogonal decomposition and variational fluid flow estimation, Journ. of Mathematical Imaging and Vison, 2006. ,
Fluid structure and motion analysis from multi-spectrum 2D cloud image sequences, Proceedings IEEE Conference on Computer Vision and Pattern Recognition. CVPR 2000 (Cat. No.PR00662), pp.744-751, 2000. ,
DOI : 10.1109/CVPR.2000.854949
