A Database and Evaluation Methodology for Optical Flow, Int. Conf. on Comp. Vis., ICCV 2007, 2007. ,
DOI : 10.1007/s11263-010-0390-2
Performance of optical flow techniques, International Journal of Computer Vision, vol.54, issue.1, pp.43-77, 1994. ,
DOI : 10.1007/BF01420984
A three-frame algorithm for estimating two-component image motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.886-895, 1992. ,
DOI : 10.1109/34.161348
The Robust Estimation of Multiple Motions: Parametric and Piecewise-Smooth Flow Fields, Computer Vision and Image Understanding, vol.63, issue.1, pp.75-104, 1996. ,
DOI : 10.1006/cviu.1996.0006
A Multigrid Platform for Real-Time Motion Computation with Discontinuity-Preserving Variational Methods, International Journal of Computer Vision, vol.44, issue.2, pp.257-277, 2006. ,
DOI : 10.1007/s11263-006-6616-7
Report 1 on production and diffusion of fluid mechanics images and data. Fluid project deliverable 1.2, 2005. ,
Fluid experimental flow estimation based on an optical-flow scheme, Experiments in Fluids, vol.10, issue.5, pp.80-97, 2006. ,
DOI : 10.1007/s00348-005-0048-y
URL : https://hal.archives-ouvertes.fr/halshs-00008138
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
DOI : 10.1109/34.990137
URL : https://hal.archives-ouvertes.fr/hal-00329724
A Low Dimensional Fluid Motion Estimator, International Journal of Computer Vision, vol.21, issue.3, pp.329-349, 2007. ,
DOI : 10.1007/s11263-007-0037-0
URL : https://hal.archives-ouvertes.fr/inserm-00140892
Wavelet-Based Fluid Motion Estimation, Scale Space Methods and Variational Methods (SSVM) in Computer Vision, 2011. ,
DOI : 10.1007/978-3-642-24785-9_62
URL : https://hal.archives-ouvertes.fr/hal-00695549
Spatially-adaptive regularized pelrecursive motion estimation based on cross-validation, International Conference on Image Processing, pp.200-203, 1998. ,
DOI : 10.1109/icip.1998.723347
Local Polynomial Modelling and its Applications, 1996. ,
DOI : 10.1007/978-1-4899-3150-4
The existence of geometrical density-image transformations corresponding to object motion, Computer Vision, Graphics, and Image Processing, vol.44, issue.2, pp.155-174, 1988. ,
DOI : 10.1016/S0734-189X(88)80003-3
Constrained restoration and the recovery of discontinuities, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.3, pp.367-383, 1992. ,
DOI : 10.1109/34.120331
Stochastic relaxation, Gibbs distributions and the Bayesian restoration of images, IEEE Trans. Pattern Anal. Mach. Intell, vol.6, issue.6, pp.721-741, 1984. ,
A fast ?Monte-Carlo cross-validation? procedure for large least squares problems with noisy data, Numerische Mathematik, vol.14, issue.1, pp.1-23, 1989. ,
DOI : 10.1007/BF01395775
Three-Dimensional Motion Estimation of Atmospheric Layers From Image Sequences, IEEE Transactions on Geoscience and Remote Sensing, vol.46, issue.8, pp.462385-2396, 2008. ,
DOI : 10.1109/TGRS.2008.918167
URL : https://hal.archives-ouvertes.fr/hal-00670348
Bayesian selection of scaling laws for motion modeling in images, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459353
URL : https://hal.archives-ouvertes.fr/hal-00473262
Layered Estimation of Atmospheric Mesoscale Dynamics From Satellite Imagery, IEEE Transactions on Geoscience and Remote Sensing, vol.45, issue.12, pp.454087-4104, 2007. ,
DOI : 10.1109/TGRS.2007.906156
URL : https://hal.archives-ouvertes.fr/hal-00596167
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1651
A Stochastic Estimator of the Trace of the Influence Matrix for Laplacian Smoothing Splines, Communications in Statistics - Simulation and Computation, vol.47, issue.3, pp.1059-1076, 1989. ,
DOI : 10.1175/1520-0493(1980)108<1122:SNMMFV>2.0.CO;2
Estimation robuste pour la détection et le suivi par caméra, Traitement du Signal, vol.21, issue.3, pp.205-226, 2004. ,
Bayesian Methods: General Background, 1986. ,
DOI : 10.1017/CBO9780511569678.003
URL : http://bayes.wustl.edu/etj/articles/general.background.ps.gz
An Introduction to Variational Methods for Graphical Models, Machine Learning, vol.37, pp.183-233, 1999. ,
DOI : 10.1007/978-94-011-5014-9_5
A maximum likelihood estimator for choosing the regularization parameters in global optic flow methods, ICIP, pp.1081-1084, 2006. ,
Bayesian Model Selection for Optical Flow Estimation, DAGM-Symposium, pp.142-151, 2007. ,
DOI : 10.1007/978-3-540-74936-3_15
Regularization Parameter Selection in Discrete Ill-Posed Problems ??? The Use of the U-Curve, International Journal of Applied Mathematics and Computer Science, vol.17, issue.2, pp.157-164, 2007. ,
DOI : 10.2478/v10006-007-0014-3
Model selection, 1986. ,
Fluid flow and optical flow, Journal of Fluid Mechanics, vol.51, p.253, 2008. ,
DOI : 10.1023/A:1013614317973
An iterative image registration technique with an application to stereovision, Int. Joint Conf. on Artificial Intel. (IJCAI), pp.674-679, 1981. ,
Bayesian Interpolation, Neural Computation, vol.49, issue.3, pp.415-447, 1992. ,
DOI : 10.1093/comjnl/11.2.185
Dense estimation and object-based segmentation of the optical flow with robust techniques, IEEE Transactions on Image Processing, vol.7, issue.5, pp.703-719, 1998. ,
DOI : 10.1109/83.668027
On the estimation of hyperparameters in Bayesian approach of solving inverse problems, IEEE International Conference on Acoustics Speech and Signal Processing, pp.495-498, 1993. ,
DOI : 10.1109/ICASSP.1993.319857
Bayesian and regularization methods for hyperparameter estimation in image restoration, IEEE Transactions on Image Processing, vol.8, issue.2, pp.231-246, 1999. ,
DOI : 10.1109/83.743857
A data-driven method for choosing smoothing parameters in optical flow problems, Proceedings of International Conference on Image Processing, pp.360-363, 1997. ,
DOI : 10.1109/ICIP.1997.632117
Numerical Optimization, Series in Operations Research, 1999. ,
DOI : 10.1007/b98874
The Bayesian Choice: From Decision-Theoretic Foundations to Computational Implementation ,
DOI : 10.1007/978-1-4757-4314-2
Convex analysis, 1970. ,
DOI : 10.1515/9781400873173
Estimating the Dimension of a Model, The Annals of Statistics, vol.6, issue.2, pp.461-464, 1978. ,
DOI : 10.1214/aos/1176344136
Empirical choice of smoothing parameters in optical flow with correlated errors, 2003 IEEE International Conference on Acoustics, Speech, and Signal Processing, 2003. Proceedings. (ICASSP '03)., pp.161-165, 2003. ,
DOI : 10.1109/ICASSP.2003.1199132
Density estimation for statistics and data analysis, 1986. ,
DOI : 10.1007/978-1-4899-3324-9
Learning Optical Flow, Proceedings of the 10th European Conference on Computer Vision, pp.83-97, 2008. ,
DOI : 10.1007/978-3-540-88690-7_7
Spline models for observational data, CBMS- NSF Regional Conference Series in Applied Mathematics. Society for Industrial and Applied Mathematics (SIAM), vol.59, 1990. ,
DOI : 10.1137/1.9781611970128
A theoretical framework for convex regularizers in pde-based computation of image motion, Int. J. Computer Vision, pp.245-264, 2004. ,
Discrete Orthogonal Decomposition and Variational Fluid Flow Estimation, Journal of Mathematical Imaging and Vision, vol.34, issue.2, pp.67-80, 2007. ,
DOI : 10.1007/s10851-007-0014-9
Consistent segmentation for optical flow estimation, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.1308-1315, 2005. ,
DOI : 10.1109/ICCV.2005.61
