The function field sieve, Algorithmic Number Theory 1st Algorithmic Number Theory Symposium -Cornell University, pp.108-121, 1994. ,
Function field sieve method for discrete logarithms over finite fields, Inf. Comput, vol.151, issue.12, pp.5-16, 1999. ,
Polynomial evaluation and interpolation on special sets of points [Cop84] D. Coppersmith. Fast evaluation of logarithms in fields of characteristic two. Information Theory, Cop94] D. Coppersmith. Solving linear equations over GF(2) via block Wiedemann algorithm, pp.420-446587, 1984. ,
An Algorithm to Solve the Discrete Logarithm Problem with the Number Field Sieve, Public key cryptography?PKC, pp.174-190, 2006. ,
DOI : 10.1007/11745853_12
On the list and bounded distance decodibility of Reed- Solomon codes On the list and bounded distance decodibility of Reed-Solomon codes, Foundations of Computer Science Proceedings. 45th Annual IEEE Symposium on, pp.335-341195, 2004. ,
Complexity Analysis of Reed-Solomon Decoding over GF without Using Syndromes, EURASIP Journal on Wireless Communications and Networking, vol.137, issue.2, 2008. ,
DOI : 10.1049/ip-com:20050022
Analytic Combinatorics, 2009. ,
DOI : 10.1017/CBO9780511801655
URL : https://hal.archives-ouvertes.fr/inria-00072739
A New Algorithm for Decoding Reed-Solomon Codes, Communications, Information and Network Security, pp.55-68, 2002. ,
DOI : 10.1007/978-1-4757-3789-9_5
Index calculus for abelian varieties of small dimension and the elliptic curve discrete logarithm problem, Journal of Symbolic Computation, vol.44, issue.12, pp.1690-1702, 1999. ,
DOI : 10.1016/j.jsc.2008.08.005
URL : https://hal.archives-ouvertes.fr/inria-00337631
Function field sieve in characteristic three Discrete logarithms in GF(p) using the number field sieve, Algorithmic Number Theory 6th International Symposium, ANTS-VI Proceedings. [Gor93], pp.223-234124, 1993. ,
On the Discrete Logarithm Problem on Algebraic Tori, Advances in Cryptology (CRYPTO 2005), pp.66-85, 2005. ,
DOI : 10.1007/11535218_5
Information Theory The function field sieve is quite special Joux and R. Lercier. Improvements to the general number field sieve for discrete logarithms in prime fields. a comparison with the gaussian integer method Joux and R. Lercier. The function field in the medium prime case, Algorihmic Number Theory 5th International Symposium, ANTS-V Proceedings. [JL03] A Advances in Cryptology ? EUROCRYPT, pp.512249-2256, 2002. ,
The Number Field Sieve in the Medium Prime Case, Advances in Cryptology -CRYPTO 2006, pp.326-344 ,
DOI : 10.1007/11818175_19
URL : https://hal.archives-ouvertes.fr/hal-01102034
A block Lanczos algorithm for finding dependencies over GF(2), Advances in Cryptology ? EUROCRYPT '95 International Conference on the Theory and Application of Cryptographic Techniques Proceedings. [Rot06], pp.106-120, 1995. ,
Introduction to Coding Theory Discrete logarithms and local units Virtual logarithms An algorithm for evaluation of discrete logarithms in some nonprime finite fields, Philos. Trans. Roy. Soc. London Ser. A J. Algorithms Math. Comp, vol.345, issue.57224, pp.409-423140, 1676. ,
A method for solving key equation for decoding goppa codes, Information and Control, vol.27, issue.1, pp.87-99, 1975. ,
DOI : 10.1016/S0019-9958(75)90090-X
Decoding of Reed-Solomon codes beyond the error-correction bound Factorization of polynomials over finite fields, J. Complexity Pacific J. Math, vol.13, issue.12, pp.180-1931099, 1962. ,
Discrete logarithms: The effectiveness of the index calculus method, Algorithmic Number Theory, volume 1122 of Lecture Notes in Comput. Sci. Second International Symposium Proceedings. [Web96] D. Weber Algorithmic Number Theory Second International Symposium, ANTS- II, pp.337-361, 1996. ,
DOI : 10.1007/3-540-61581-4_66
