Wireless sensor network redeployment under the target coverage constraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dimitrios Zorbas
  • Fonction : Auteur
  • PersonId : 921283
Tahiry Razafindralambo
A critical problem of wireless sensor networks is the efficient handling of the nodes energy under the target coverage constraint. The sensors are randomly deployed in the field covering a set of targets. Due to the randomness of the deployment some targets are covered by a few only sensors and, thus, the maximum achieved network lifetime is upper bounded by the energy of the sensors that cover the most sparsely covered target. To tackle this problem one could move some sensors towards sparsely covered areas from areas that are covered by many sensors. In this paper we present a localized solution that can be used to redeploy the sensing nodes and balance the amount of energy between the sensors that cover each target, while it also ensures connectivity with the sink. We simulate our approach and our findings show an over 100% increase of the amount of energy of the sensors that cover the most sparsely covered target in the network. We compare our findings to the theoretical maximum solution and to the case where the nodes are considered static.
Fichier non déposé
hal-00673348 , version 1 (23-02-2012)
  • HAL Id : hal-00673348 , version 1
Dimitrios Zorbas, Tahiry Razafindralambo. Wireless sensor network redeployment under the target coverage constraint. NTMS 2012: The Fifth IFIP International Conference on New Technologies, Mobility and Security, May 2012, Istanbul, Turkey. ⟨hal-00673348⟩
Collections
INRIA INRIA2
119 Consultations
0 Téléchargements
