The significance of reducing setup times/setup costs, European Journal of Operational Research, vol.187, issue.3, pp.978-984, 2008. ,
DOI : 10.1016/j.ejor.2006.09.010
A survey of scheduling problems with setup times or costs, European Journal of Operational Research, vol.187, issue.3, pp.985-1032, 2008. ,
DOI : 10.1016/j.ejor.2006.06.060
Mapping pipeline skeletons onto heterogeneous platforms, Journal of Parallel and Distributed Computing, vol.68, issue.6, pp.790-808, 2008. ,
DOI : 10.1016/j.jpdc.2007.11.004
URL : https://hal.archives-ouvertes.fr/hal-00118921
Efficient collective communication in distributed heterogeneous systems, 19th ICDCS'99, pp.15-24, 1999. ,
Efficient collective communication in distributed heterogeneous systems, JPDC, vol.63, pp.251-263, 2003. ,
Scheduling flowshops with finite buffers and sequence-dependent setup times, Comp. & Indus. Engineering, vol.36, issue.199, pp.163-177, 1999. ,
Modular architecture of the microfactories for automatic micro-assembly, Robotics and Computer-Integrated Manufacturing, vol.26, issue.4, pp.354-360, 2010. ,
DOI : 10.1016/j.rcim.2009.11.013
URL : https://hal.archives-ouvertes.fr/hal-00503826
ACO-based scheduling for a single Batch Processing Machine in semiconductor manufacturing, 2008 IEEE International Conference on Automation Science and Engineering, pp.85-90, 2008. ,
DOI : 10.1109/COASE.2008.4626455
ACO-based scheduling of parallel batch processing machines to minimize the total weighted tardiness, 2009 IEEE International Conference on Automation Science and Engineering, pp.280-285, 2009. ,
DOI : 10.1109/COASE.2009.5234191
Job shop scheduling with groupdependent setups, finite buffers, and long time horizon, Annals of Operations Research, vol.76, pp.233-259, 1998. ,
DOI : 10.1023/A:1018948621875
-stage flowshop with sequence dependent set-up times, International Journal of Production Research, vol.3, issue.6, pp.1459-1474, 1986. ,
DOI : 10.1080/00207547708943117
Optimal mapping of sequences of data parallel tasks, ACM SIGPLAN Notices, pp.134-143, 1995. ,
Optimal latency-throughput tradeoffs for data parallel pipelines, Proceedings of the eighth annual ACM symposium on Parallel algorithms and architectures , SPAA '96, p.71, 1996. ,
DOI : 10.1145/237502.237508
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.6335
Calibration of Wafer Handling Robots: A Fixturing Approach, 2007 IEEE International Conference on Automation Science and Engineering, pp.255-260, 2007. ,
DOI : 10.1109/COASE.2007.4341769
Inovallée 655 avenue de l'Europe Montbonnot 38334 Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria, pp.249-6399 ,
