Explicit-formulas database ,
Faster Addition and Doubling on Elliptic Curves, ASIACRYPT 2007, pp.29-50, 2007. ,
DOI : 10.1007/978-3-540-76900-2_3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.117.4261
On the security of 1024-bit rsa and 160-bit elliptic curve cryptography, 2009. ,
Speeding up discrete log and factoring based schemes via precomputations, 1998. ,
DOI : 10.1007/BFb0054129
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.36.688
Weierstra?? Elliptic Curves and Side-Channel Attacks, PKC 2002, pp.335-345, 2002. ,
DOI : 10.1007/3-540-45664-3_24
Sec 2: Recommended elliptic curve domain parameters standards for efficient cryptography, Certicom, 2000. ,
Efficient Elliptic Curve Exponentiation Using Mixed Coordinates, ASIACRYPT 1998, pp.51-65, 1998. ,
DOI : 10.1007/3-540-49649-1_6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.26.2566
On Schnorr's preprocessing for digital signature schemes, EUROCRYPT 1993, pp.435-439, 1994. ,
Efficient and Secure Elliptic Curve Point Multiplication Using Double-Base Chains, ASIACRYPT 2005, pp.59-78, 2005. ,
DOI : 10.1007/11593447_4
URL : https://hal.archives-ouvertes.fr/lirmm-00106638
Concrete Mathematics: A Foundation for Computer Science, Computers in Physics, vol.3, issue.5, 1989. ,
DOI : 10.1063/1.4822863
Guide to Elliptic Curve Cryptography, 2004. ,
Twisted Edwards Curves Revisited, ASIACRYPT 2008, pp.326-343, 2008. ,
DOI : 10.1007/BFb0053453
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.215.3196
Random small Hamming weight products with applications to cryptography, Discrete Applied Mathematics, vol.130, issue.1, pp.37-49, 2003. ,
DOI : 10.1016/S0166-218X(02)00588-7
Fast generation of pairs (k, [k]p) for koblitz elliptic curves, SAC 2001, pp.151-174, 2001. ,
Hessian Elliptic Curves and Side-Channel Attacks, CHES 2001, pp.402-410, 2001. ,
DOI : 10.1007/3-540-44709-1_33
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.1196
Factorization of a 768-Bit RSA Modulus, 2010. ,
DOI : 10.1007/978-3-642-14623-7_18
URL : https://hal.archives-ouvertes.fr/inria-00444693
Analysis of the subtractive algorithm for greater common divisors, Proc. Nat. Acad. Sci. USA, pp.4720-4722, 1975. ,
The Art of Computer Programming: Fundamental Algorithms, 1997. ,
CM-Curves with Good Cryptographic Properties, CRYPTO 1991, pp.279-287, 1992. ,
DOI : 10.1007/3-540-46766-1_22
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.137.6778
Analyzing and comparing Montgomery multiplication algorithms, IEEE Micro, vol.16, issue.3, pp.26-33, 1996. ,
DOI : 10.1109/40.502403
Differential Power Analysis, CRYPTO 1999, pp.388-397, 1999. ,
DOI : 10.1007/3-540-48405-1_25
Preventing SPA/DPA in ECC Systems Using the Jacobi Form, CHES 2001, pp.391-401, 2001. ,
DOI : 10.1007/3-540-44709-1_32
Setting speed records with the (fractional) multibase nonadjacent form method for efficient elliptic curve scalar multiplication, Public Key Cryptography ? PKC 2009, pp.443-462, 2009. ,
New Composite Operations and Precomputation Scheme for Elliptic Curve Cryptosystems over Prime Fields, PKC 2008, pp.229-247, 2008. ,
DOI : 10.1007/978-3-540-78440-1_14
Arithmétique pour la Cryptographie basée sur les Courbes Elliptiques, 2007. ,
New Point Addition Formulae for ECC Applications, WAIFI 2007, pp.189-201, 2007. ,
DOI : 10.1007/978-3-540-73074-3_15
URL : https://hal.archives-ouvertes.fr/lirmm-00188957
Hard Instances of the Constrained Discrete Logarithm Problem, ANTS 2006, pp.582-598, 2006. ,
DOI : 10.1007/11792086_41
Securing Elliptic Curve Point Multiplication against Side-Channel Attacks, ISC 2001, pp.324-334, 2001. ,
DOI : 10.1007/3-540-45439-X_22
Improved Techniques for Fast Exponentiation, ICISC 2002, pp.298-312, 2003. ,
DOI : 10.1007/3-540-36552-4_21
Speeding the Pollard and elliptic curve methods of factorization, Mathematics of Computation, vol.48, issue.177, pp.243-264, 1987. ,
DOI : 10.1090/S0025-5718-1987-0866113-7
Evaluating recurrences of form Xm+n = f (Xm, Xn, Xm?n) via Lucas chains, 1992. ,
On the low hamming weight discrete logarithm problem for nonadjacent representations, Applicable Algebra in Engineering, Communication and Computing, vol.16, pp.461-472, 2006. ,
The Hardness of the Hidden Subset Sum Problem and Its Cryptographic Implications, CRYPTO 1999, pp.31-46, 1999. ,
DOI : 10.1007/3-540-48405-1_3
Regularity properties of the stern enumeration of the rationals, Journal of Integer Sequences, vol.11, 2008. ,
Efficient signature generation by smart cards, Journal of Cryptology, vol.4, issue.3, pp.161-174, 1991. ,
DOI : 10.1007/BF00196725
URL : http://publikationen.ub.uni-frankfurt.de/files/4280/schnorr.pdf
¨ uber eine zahlentheoretische funktion, Journal für die reine und angewandte Mathematik, pp.193-220, 1858. ,
DOI : 10.1515/crll.1858.55.193
URL : http://www.digizeitschriften.de/download/PPN243919689_0055/PPN243919689_0055___log15.pdf
Some baby-step giant-step algorithms for the low hamming weight discrete logarithm problem, Mathematics of Computation, vol.71, issue.237, pp.379-391, 2000. ,
DOI : 10.1090/S0025-5718-01-01310-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.101.4665
