Information-Theoretic Lower Bounds on the Oracle Complexity of Stochastic Convex Optimization, IEEE Transactions on Information Theory, vol.58, issue.5, pp.58-2012 ,
DOI : 10.1109/TIT.2011.2182178
Non-asymptotic analysis of stochastic approximation algorithms for machine learning, NIPS, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00608041
A New Class of Incremental Gradient Methods for Least Squares Problems, SIAM Journal on Optimization, vol.7, issue.4, pp.913-926, 1997. ,
DOI : 10.1137/S1052623495287022
A Convergent Incremental Gradient Method with a Constant Step Size, SIAM Journal on Optimization, vol.18, issue.1, pp.29-51, 2007. ,
DOI : 10.1137/040615961
The tradeoffs of large scale learning, NIPS, 2007. ,
Large scale online learning, NIPS, 2003. ,
Méthode générale pour la résolution des systèmes d'´ equations simultanées, Comptes rendus des séances de l'Académie des sciences de Paris, pp.536-538, 1847. ,
Accelerated Stochastic Approximation, SIAM Journal on Optimization, vol.3, issue.4, pp.868-881, 1993. ,
DOI : 10.1137/0803045
Optimal learning rates for least squares SVMs using Gaussian kernels, NIPS, 2011. ,
Hybrid deterministic-stochastic methods for data fitting, SIAM Journal of Scientific Computing, vol.34, issue.3, pp.1351-1379, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00626571
Optimal stochastic' approximation algorithms for strongly convex stochastic composite optimization, Optimization Online, 2010. ,
Beyond the regret minimization barrier: an optimal algorithm for stochastic strongly-convex optimization. COLT, 2011. ,
Accelerated Stochastic Approximation, The Annals of Mathematical Statistics, vol.29, issue.1, pp.41-59, 1958. ,
DOI : 10.1214/aoms/1177706705
Stochastic approximation and recursive algorithms and applications, 2003. ,
Asymptotically optimal regularization in smooth parametric models, NIPS, 2009. ,
Large-scale sparse logistic regression, Proceedings of the 15th ACM SIGKDD international conference on Knowledge discovery and data mining, KDD '09, 2009. ,
DOI : 10.1145/1557019.1557082
Deep learning via Hessian-free optimization, ICML, 2010. ,
Convergence rate of incremental subgradient algorithms, Stochastic Optimization: Algorithms and Applications, pp.263-304, 2000. ,
Problem complexity and method efficiency in optimization, 1983. ,
Robust Stochastic Approximation Approach to Stochastic Programming, SIAM Journal on Optimization, vol.19, issue.4, pp.1574-1609, 2009. ,
DOI : 10.1137/070704277
URL : https://hal.archives-ouvertes.fr/hal-00976649
A method for unconstrained convex minimization problem with the rate of convergence, Doklady AN SSSR, vol.269, issue.1 23, pp.543-547, 1983. ,
Introductory lectures on convex optimization: A basic course, 2004. ,
DOI : 10.1007/978-1-4419-8853-9
Primal-dual subgradient methods for convex problems, Mathematical Programming, vol.8, issue.1, pp.221-259, 2009. ,
DOI : 10.1007/s10107-007-0149-x
Efficiency of Coordinate Descent Methods on Huge-Scale Optimization Problems, SIAM Journal on Optimization, vol.22, issue.2, 2010. ,
DOI : 10.1137/100802001
Acceleration of Stochastic Approximation by Averaging, SIAM Journal on Control and Optimization, vol.30, issue.4, pp.838-855, 1992. ,
DOI : 10.1137/0330046
A Stochastic Approximation Method, The Annals of Mathematical Statistics, vol.22, issue.3, pp.400-407, 1951. ,
DOI : 10.1214/aoms/1177729586
Local gain adaptation in stochastic gradient descent, 9th International Conference on Artificial Neural Networks: ICANN '99, 1999. ,
DOI : 10.1049/cp:19991170
Pegasos, Proceedings of the 24th international conference on Machine learning, ICML '07, 2007. ,
DOI : 10.1145/1273496.1273598
Incremental gradient algorithms with stepsizes bounded away from zero, Computational Optimization and Applications, vol.11, issue.1, pp.23-35, 1998. ,
DOI : 10.1023/A:1018366000512
Fast rates for regularized objectives, NIPS, 2008. ,
A scalable modular convex solver for regularized risk minimization, Proceedings of the 13th ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '07, 2007. ,
DOI : 10.1145/1281192.1281270
An Incremental Gradient(-Projection) Method with Momentum Term and Adaptive Stepsize Rule, SIAM Journal on Optimization, vol.8, issue.2, pp.506-531, 1998. ,
DOI : 10.1137/S1052623495294797
Dual averaging methods for regularized stochastic learning and online optimization, Journal of Machine Learning Research, vol.11, pp.2543-2596, 2010. ,
