On MISTY1 Higher Order Differential Cryptanalysis, Proceedings of ICISC 2000, number 2015 in Lecture Notes in Computer Science, pp.22-36, 2000. ,
DOI : 10.1007/3-540-45247-8_3
Differential cryptanalysis of DES-like cryptosystems, Journal of Cryptology, vol.36, issue.4, pp.3-72, 1991. ,
DOI : 10.1007/BF00630563
Differential cryptanalysis of Feistel ciphers and differentially uniform mappings, Selected Areas on Cryptography, SAC'97, pp.172-184, 1997. ,
Binary m-sequences with three-valued crosscorrelation: a proof of Welch's conjecture, IEEE Transactions on Information Theory, vol.46, issue.1, pp.4-8, 2000. ,
DOI : 10.1109/18.817504
Weight Divisibility of Cyclic Codes, Highly Nonlinear Functions on F2m, and Crosscorrelation of Maximum-Length Sequences, SIAM Journal on Discrete Mathematics, vol.13, issue.1, pp.105-138, 2000. ,
DOI : 10.1137/S0895480198350057
Weakness of block ciphers using highly nonlinear confusion functions, research report, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072221
Codes, bent functions and permutations suitable for DES-like cryptosystems. Designs, Codes and Cryptography, pp.125-156, 1998. ,
Links between differential and linear cryptanalysis, Advances in Cryptology -EUROCRYPT'94, number 950 in Lecture Notes in Computer Science, pp.356-365, 1995. ,
DOI : 10.1007/BFb0053450
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.4694
On binary cyclic codes with minimum distance d = 3. Problems of Information Transmission, pp.287-296, 1997. ,
Some new three-valued crosscorrelation functions for binary m-sequences, IEEE Transactions on Information Theory, vol.42, issue.4, pp.1238-1240, 1996. ,
DOI : 10.1109/18.508848
AES proposal: the Rijndael block cipher Available at http://csrc.nist.gov/encryption, 1999. ,
One-to-One Highly Nonlinear Power Functions on GF(2 n ), Applicable Algebra in Engineering, Communication and Computing, vol.9, issue.2 ,
DOI : 10.1007/s002000050099
Maximal recursive sequences with 3-valued recursive cross-correlation functions (Corresp.), IEEE Transactions on Information Theory, vol.14, issue.1, pp.154-156, 1968. ,
DOI : 10.1109/TIT.1968.1054106
Cryptanalysis of iterated block ciphers, of ETH Series in Information Processing. Hartung-Gorre Verlag, 1996. ,
A Generalization of Linear Cryptanalysis and the Applicability of Matsui???s Piling-up Lemma, Advances in Cryptology -EUROCRYPT'95, number 921 in Lecture Notes in Computer Science, pp.24-38, 1995. ,
DOI : 10.1007/3-540-49264-X_3
Some results about the cross-correlation function between two maximal linear sequences, Discrete Mathematics, vol.16, issue.3, pp.209-232, 1976. ,
DOI : 10.1016/0012-365X(76)90100-X
A proof of the Welch and Niho conjectures on crosscorrelations of binary m-sequences. Finite Fields and Their Applications, pp.253-286, 2001. ,
Cryptanalysis of block ciphers with probabilistic nonlinear relations of low degree, Advances in Cryptology -CRYPTO'98, number 1462 in Lecture Notes in Computer Science, pp.212-222, 1998. ,
Higher-order cryptanalysis of block ciphers, 1999. ,
The interpolation attack on block ciphers, Fast Software Encryption 97, number 1267 in Lecture Notes in Computer Science, 1997. ,
DOI : 10.1007/BFb0052332
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.7252
Weight distributions of Bose-Chaudhuri-Hocquenghem codes The Univ, Proceedings of the conference on combinatorial mathematics and its applications, pp.335-357, 1968. ,
The weight enumerators for several classes of subcodes of the 2nd order binary Reed-Muller codes, Information and Control, vol.18, issue.4, pp.369-394, 1971. ,
DOI : 10.1016/S0019-9958(71)90473-6
Truncated and higher order differentials In Fast Software Encryption -Second International Workshop, number 1008 in Lecture Notes in Computer Science, pp.196-211, 1995. ,
On the validity of certian hypotheses used in linear cryptanalysis, of ETH Series in Information Processing. Hartung- Gorre Verlag, 1999. ,
The weights of the orthogonals of the extended quadratic binary Goppa codes, IEEE Transactions on Information Theory, vol.36, issue.3, pp.686-692, 1990. ,
DOI : 10.1109/18.54892
Higher Order Derivatives and Differential Cryptanalysis, Proc. " Symposium on Communication, Coding and Cryptography honor of J. L. Massey on the occasion of his 60'th birthday, 1994. ,
DOI : 10.1007/978-1-4615-2694-0_23
Linear Cryptanalysis Method for DES Cipher, Advances in Cryptology -EUROCRYPT'93, number 765 in Lecture Notes in Computer Science, 1994. ,
DOI : 10.1007/3-540-48285-7_33
The First Experimental Cryptanalysis of the Data Encryption Standard, Advances in Cryptology -CRYPTO'94, number 839 in Lecture Notes in Computer Science, 1995. ,
DOI : 10.1007/3-540-48658-5_1
New block encryption algorithm MISTY, Proceedings of the Fourth International Workshop of Fast Software Encryption , number 1267 in Lecture Notes in Computer Science, pp.54-68, 1997. ,
DOI : 10.1007/BFb0052334
Weight congruences for p-ary cyclic codes, Discrete Mathematics, vol.3, issue.1-3, pp.177-192, 1972. ,
DOI : 10.1016/0012-365X(72)90032-5
Nonlinearity Criteria for Cryptographic Functions, Advances in Cryptology -EUROCRYPT'89, number 434 in Lecture Notes in Computer Science, pp.549-562, 1990. ,
DOI : 10.1007/3-540-46885-4_53
Perfect nonlinear S-boxes, Advances in Cryptology - EUROCRYPT'91, number 547 in Lecture Notes in Computer Science, pp.378-385, 1991. ,
DOI : 10.1007/3-540-46416-6_32
Differentially uniform mappings for cryptography, Advances in Cryptology -EUROCRYPT'93, number 765 in Lecture Notes in Computer Science, pp.55-64, 1993. ,
DOI : 10.1007/3-540-48285-7_6
Provable Security Against Differential Cryptanalysis, Advances in Cryptology -CRYPTO'92, number 740 in Lecture Notes in Computer Science, pp.566-574, 1993. ,
DOI : 10.1007/3-540-48071-4_41
Power moment identities on weight distributions in errorcorrecting codes, Info. and Control, vol.3, pp.147-152, 1963. ,
Crosscorrelation properties of pseudorandom and related sequences, Proceedings of the IEEE, vol.68, issue.5, pp.593-619, 1980. ,
DOI : 10.1109/PROC.1980.11697
On mutual correlation of sequences, Soviet Math. Dokl, vol.12, pp.197-201, 1971. ,
Strength of MISTY1 without FL function for Higher Order Differential Attack, Applied Algebra, Algebraic Algorithms and Error-Correcting Codes, number 1719 in Lecture Notes in Computer Science, pp.221-230, 1999. ,
