Encoder decoder design for event-triggered feedback control over bandlimited channels, American Control Conference, pp.4183-4188, 2006. ,
Dynamic Programming, 1957. ,
Dynamic Programming and Suboptimal Control: A Survey from ADP to MPC*, European Journal of Control, vol.11, issue.4-5, 2005. ,
DOI : 10.3166/ejc.11.310-334
Stochastic Optimal Control: The Discrete Time Case, Athena Scientific, 1978. ,
Wireless Sensor Network Radio Power Management and Simulation Models~!2009-02-13~!2010-01-15~!2010-02-23~!, The Open Electrical & Electronic Engineering Journal, vol.4, issue.1, pp.21-31, 2010. ,
DOI : 10.2174/1874129001004010021
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.468.57
A Constant Factor Approximation Algorithm for Event-Based Sampling, 2007 American Control Conference, pp.305-311, 2007. ,
DOI : 10.1109/ACC.2007.4282991
Optimal Control and Scheduling of Switched Systems, IEEE Transactions on Automatic Control, vol.56, issue.1, 2011. ,
DOI : 10.1109/TAC.2010.2085573
On a stochastic sensor selection algorithm with applications in sensor scheduling and sensor coverage, Automatica, vol.42, issue.2, pp.251-260, 2006. ,
DOI : 10.1016/j.automatica.2005.09.016
Optimal estimation with limited measurements, International Journal of Systems, Control and Communications, vol.2, issue.1/2/3, pp.5-29, 2010. ,
DOI : 10.1504/IJSCC.2010.031156
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.74.7830
Bounds on Dynamic Modulation Scaling for Wireless Sensor Networks, 2007 Third International Conference on Wireless Communication and Sensor Networks, pp.13-16, 2007. ,
DOI : 10.1109/WCSN.2007.4475738
Adaptive Radio Modes in Sensor Networks: How Deep to Sleep?, 2008 5th Annual IEEE Communications Society Conference on Sensor, Mesh and Ad Hoc Communications and Networks, pp.386-394, 2008. ,
DOI : 10.1109/SAHCN.2008.54
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.211.9602
A survey on data compression in wireless sensor networks, International Conference on Information Technology: Coding and Computing (ITCC'05), Volume II, pp.8-13, 2005. ,
DOI : 10.1109/ITCC.2005.43
Dynamic Programming and Time-Varying Delay Systems, 2003. ,
Wireless sensor networks: guidelines for design and a survey of current research ,
Energy Efficient State Estimation With Wireless Sensors Through the Use of Predictive Power Control and Coding, IEEE Transactions on Signal Processing, vol.58, issue.9, pp.4811-4823, 2010. ,
DOI : 10.1109/TSP.2010.2050883
Dynamic power management in wireless sensor networks, IEEE Design & Test of Computers, vol.18, issue.2, pp.62-74, 2001. ,
DOI : 10.1109/54.914626
Kalman Filtering With Intermittent Observations, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.1453-1464, 2004. ,
DOI : 10.1109/TAC.2004.834121
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.129.8561
On Implementation of Dynamic Programming for Optimal Control Problems with Final State Constraints, Oil & Gas Science and Technology ??? Revue de l???Institut Fran??ais du P??trole, vol.65, issue.1, pp.91-102, 2010. ,
DOI : 10.2516/ogst/2009020
Optimal power analysis for network lifetime balance in wireless sensor networks, 2007 International Symposium on Communications and Information Technologies, pp.1161-1165, 2007. ,
DOI : 10.1109/ISCIT.2007.4392192
Estimation under uncontrolled and controlled communications in networked control systems, 44th IEEE Conference on Decision and Control, 2005 and 2005 European Control Conference. CDC-ECC '05, pp.842-847, 2005. ,
