HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Numerical investigation on the Total Sensitivity Index influence in the solution of stochastic partial differential equations
Remi Abgrall 1, 2 Pietro Marco Congedo 1 Gianluca Geraci 1
1 BACCHUS - Parallel tools for Numerical Algorithms and Resolution of essentially Hyperbolic problems
CNRS - Centre National de la Recherche Scientifique : UMR5800, UB - Université de Bordeaux, Inria Bordeaux - Sud-Ouest
Abstract : In the present work a criterion on the reduction of the stochastic dimensions has been investigated in the context of the stochastic partial differential equations. Three different types of equations have been analyzed: elliptical, parabolic and an hyperbolic. For each equation, both mean and variance have been computed on some scalar output of interest. The complete and the reduced models have been compared in terms of statistical moments. The validity and the efficiency of a criterion based on TSI index has been investigated, and an error correlation has been found between the error on the variance and the TSI, that will be validated in a future work for more complex equations.
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-00681405
Contributor : Pietro Marco Congedo Connect in order to contact the contributor
Submitted on : Monday, August 31, 2015 - 11:16:43 AM
Last modification on : Wednesday, February 2, 2022 - 3:54:06 PM
Long-term archiving on: : Tuesday, December 1, 2015 - 10:24:19 AM
File
RR-7911.pdf
Identifiers
  • HAL Id : hal-00681405, version 2
Collections
Citation
Remi Abgrall, Pietro Marco Congedo, Gianluca Geraci. Numerical investigation on the Total Sensitivity Index influence in the solution of stochastic partial differential equations. [Research Report] RR-7911, INRIA Bordeaux, équipe CARDAMOM. 2012, pp.19. ⟨hal-00681405v2⟩
Share
Metrics
Record views
197
Files downloads
73
