Control schemes for teleoperation with time delay: A comparative study, Robotics and Autonomous Systems, vol.38, issue.1, pp.49-64, 2002. ,
DOI : 10.1016/S0921-8890(01)00164-6
Applications of Time Delay Systems, 2007. ,
DOI : 10.1007/978-3-540-49556-7
A new Lyapunov technique for robust control of systems with uncertain non-small delays, IMA Journal of Mathematical Control and Information, vol.23, issue.2, pp.165-179, 2006. ,
DOI : 10.1093/imamci/dni051
On complete Lyapunov???Krasovskii functional techniques for uncertain systems with fast-varying delays, International Journal of Robust and Nonlinear Control, vol.40, issue.3, pp.364-374, 2008. ,
DOI : 10.1002/rnc.1230
New bounded real lemma representations for time-delay systems and their applications, IEEE Transactions on Automatic Control, vol.46, issue.12, pp.1973-1979, 2001. ,
DOI : 10.1109/9.975503
Parameter-Dependent Lyapunov Functional for Stability of Time-Delay Systems With Polytopic-Type Uncertainties, IEEE Transactions on Automatic Control, vol.49, issue.5, pp.828-832, 2002. ,
DOI : 10.1109/TAC.2004.828317
Bilateral teleoperation: An historical survey, Automatica, vol.42, issue.12, pp.42-2035, 2006. ,
DOI : 10.1016/j.automatica.2006.06.027
On H ? control for linear systems with interval time-varying delay, Automatica, issue.12, pp.41-2099, 2005. ,
A Switched System Approach to Exponential Stabilization Through Communication Network, IEEE Transactions on Control Systems Technology, vol.20, issue.4, 2011. ,
DOI : 10.1109/TCST.2011.2159793
Passivity-based control for bilateral teleoperation: a tutorial, Automatica, issue.3, pp.47-485, 2011. ,
Reciprocally convex approach to stability of systems with time-varying delays, Automatica, vol.47, issue.1, pp.235-238, 2011. ,
DOI : 10.1016/j.automatica.2010.10.014
Time-delay systems: an overview of some recent advances and open problems, Automatica, vol.39, issue.10, pp.39-1667, 2003. ,
DOI : 10.1016/S0005-1098(03)00167-5
Time domain passivity control with reference energy following, IEEE Trans. Contr. Syst. Technol, vol.13, issue.5, pp.737-742, 2005. ,
Delay-dependent/delayindependent stability of linear systems with multiple timevarying delays, IEEE Trans. Automat. Contr, vol.48, issue.4, pp.697-701, 2003. ,
New results on delay-dependent robust <mml:math altimg="si24.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mo>???</mml:mo></mml:mrow></mml:msub></mml:math> control for systems with time-varying delays, Automatica, vol.42, issue.2, pp.343-348, 2006. ,
DOI : 10.1016/j.automatica.2005.09.013
Time domain passivity control of teleoperation systems with random asymmetric time delays, Proceedings of the 48h IEEE Conference on Decision and Control (CDC) held jointly with 2009 28th Chinese Control Conference, pp.7533-7538, 2009. ,
DOI : 10.1109/CDC.2009.5399893
Tracking improvement based on the proxy control scheme for bilateral teleoperation system under time-varying delays, ETFA2011, 2011. ,
DOI : 10.1109/ETFA.2011.6059058
URL : https://hal.archives-ouvertes.fr/hal-00602337
