Integration of visual and depth information for vehicle detection - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
In this work an object class recognition method is presented. The method uses local image features and follows the part based detection approach. It fuses intensity and depth information in a probabilistic framework. The depth of each local feature is used to weight the probability of finding the object at a given scale. To train the system for an object class only a database of annotated with bounding boxes images is required, thus automatizing the extension of the system to different object classes. We apply our method in the problem of detecting vehicles captured from a moving platform. The experiments in a data-set of stereo images captured in an urban environment show a significant improvement in performance when using both information modalities.
Makris_IROS11_Workshop_final.pdf (571.21 Ko) Télécharger le fichier
Dates and versions
hal-00683755 , version 1 (29-03-2012)
Identifiers
  • HAL Id : hal-00683755 , version 1
Cite
Alexandros Makris, Mathias Perrollaz, Igor Paromtchik, Christian Laugier. Integration of visual and depth information for vehicle detection. International Conference on Intelligent Robots and Systems, Workshop on Perception and Navigation for Autonomous Vehicles in Human Environment, 2011, San Francisco, United States. ⟨hal-00683755⟩
123 View
105 Download
Share
