A new approach to linear filtering and prediction problems, Transactions of the ASME-Journal of Basic Engineering, vol.82, pp.35-45, 1960. ,
Recursive state estimation: Unknown but bounded errors and system inputs, IEEE Trans. Automat. Contr, vol.13, issue.1, pp.22-28, 1968. ,
Sets of possible states of linear systems given perturbed observations, IEEE Trans. Automat. Contr, vol.13, pp.556-558, 1968. ,
Recursive state estimation for a setmembership description of uncertainty, IEEE Trans. Automat. Contr, vol.16, issue.2, pp.117-128, 1971. ,
Exact recursive polyhedral description of the feasible parameter set for bounded-error models, IEEE Trans. Automat. Contr, vol.34, issue.8, pp.911-915, 1989. ,
Sequential approximation of feasible parameter sets for identification with set membership uncertainty, IEEE Trans. Automat. Contr, vol.41, pp.774-785, 1996. ,
A state bounding observer based on zonotopes, Proc. of European Control Conference, 2003. ,
Ellipsoidal parameter or state estimation under model uncertainty, Automatica, vol.40, pp.1171-1179, 2004. ,
Guaranteed state estimation by zonotopes, Automatica, vol.41, pp.1035-1043, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00632977
Reachability analysis of linear systems with uncertain parameters and inputs, Proc. of the 46th IEEE Conference on Decision and Control, vol.41, pp.726-732, 2007. ,
Ellipsoidal calculus for estimation and control, 1996. ,
Rigorously computed orbits of dynamical systems without the wrapping effect, Computing, vol.61, pp.47-67, 1998. ,
On ellipsoidal techniques for reachability analysis. Part I: External approximations, Optimization Methods and Software, vol.17, pp.177-206, 2001. ,
Zonotopes as bounding volume, Proc. of the Symposium on Discrete Algorithm, pp.803-812, 2005. ,
Robust fault detection using zonotope-based set-membership consistency test, International Journal of Adaptive Control and Signal Processing, vol.23, issue.4, pp.311-330, 2008. ,
Diagonostic et approaches ensemblistes base des zonotopes, 2008. ,
, Applied Interval Analysis, 2001.
Robust control for a class of interval model: application to the force control of piezoelectric cantilevers, Proc. of the 49th IEEE Conference on Decision and Control, 2010. ,
A new approach for guaranteed state estimation by zonotopes, Proc. of the 18th World Congress IFAC, 2011. ,
Simplified sufficient conditions for the asymptotic stability of interval matrices, International Journal of Control, vol.50, issue.1, pp.443-444, 1989. ,
Necessary and sufficient conditions for componentwise stability of interval matrix systems, IEEE Trans. Automat. Contr, vol.49, issue.6, pp.1016-1021, 2004. ,
A new vertex result for robustness problems with interval matrix uncertainty, Systems and Control Letters, vol.57, pp.474-481, 2008. ,
, Linear Matrix Inequalities in System and Control Theory, 1994.
, Numerical Analysis, 2000.
