Partial Model Checking using Networks of Labelled Transition Systems and Boolean Equation Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Partial model checking was proposed by Andersen in 1995 to verify a temporal logic formula compositionally on a composition of processes. It consists in incrementally incorporating into the formula the behavioural information taken from one process - an operation called quotienting - to obtain a new formula that can be verified on a smaller composition from which the incorporated process has been removed. Simplifications of the formula must be applied at each step, so as to maintain the formula at a tractable size. In this paper, we revisit partial model checking. First, we extend quotienting to the network of labelled transition systems model, which subsumes most parallel composition operators, including m among n synchronisation and parallel composition using synchronisation interfaces, available in the E-LOTOS standard. Second, we reformulate quotienting in terms of a simple synchronous product between a graph representation of the formula (called formula graph) and a process, thus enabling quotienting to be implemented efficiently and easily, by reusing existing tools dedicated to graph compositions. Third, we propose simplifications of the formula as a combination of bisimulations and reductions using Boolean equation systems applied directly to the formula graph, thus enabling formula simplifications also to be implemented easily and efficiently. Finally, we describe an implementation in the CADP (Construction and Analysis of Distributed Processes) toolbox and present some experimental results in which partial model checking uses hundreds of times less memory than on-the-fly model checking.
Lang-Mateescu-12.pdf (241.08 Ko) Télécharger le fichier
hal-00684471 , version 1 (02-04-2012)
  • HAL Id : hal-00684471 , version 1
Frédéric Lang, Radu Mateescu. Partial Model Checking using Networks of Labelled Transition Systems and Boolean Equation Systems. Tools and Algorithms for the Construction and Analysis of Systems, Mar 2012, Tallinn, Estonia. ⟨hal-00684471⟩
591 Consultations
142 Téléchargements
