Running parallel applications with topology-aware grid middleware
Index Terms IEEE Terms Biological system modeling , Cities and towns , Collaboration , Computational modeling , Concurrent computing , Evolutionary computation , Genetics , Grid computing , Middleware , Topology INSPEC Controlled Indexing evolutionary computation , grid computing , middleware , parallel programming , topology Non Controlled Indexing Grid'5000 , complex systems , evolutionary algorithm , geographically distributed clusters , modeling-implementing-executing cycle , multi-body simulation , parallel applications , parallelized computational models , reverse-engineering gene regulatory networks , stellar evolution , topology-aware grid middleware , topology-aware simulations Author Keywords Grid , MPI , QCG-OMPI , QosCosGrid , topology-aware Additional Details References (11) Citing Documents (1) On page(s): 292 Conference Location : Oxford Print ISBN: 978-0-7695-3877-8 INSPEC Accession Number: 11101974 Digital Object Identifier : 10.1109/e-Science.2009.48 Date of Current Version : 15 janvier 2010 Issue Date : 9-11 Dec. 2009 Related Content The cycle server: a Web platform for running parallel Monte Carlo applications on a heterogeneous Condor pool of workstations Performance Measurement and Analysis of High-Performance Parallel Applications over Lambda Grid Performance models for dynamic tuning of parallel applications on Computational Grids Co-Ordination of Parallel GRID Applications using Synchronizers Gridhra A Web Launched Parallel Application Debugger for Grids with Heterogeneous Resources
