A Parallel Hybrid Genetic Algorithm for Protein Structure Prediction on the Computational Grid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Future Generation Computer Systems Année : 2006
Solving the structure prediction problem for complex proteins is difficult and computationally expensive. In this paper, we propose a bicriterion parallel hybrid genetic algorithm (GA) in order to efficiently deal with the problem using the computational grid. The use of a near-optimal metaheuristic, such as a GA, allows a significant reduction in the number of explored potential structures. However, the complexity of the problem remains prohibitive as far as large proteins are concerned, making the use of parallel computing on the computational grid essential for its efficient resolution. A conjugated gradient-based Hill Climbing local search is combined with the GA in order to intensify the search in the neighborhood of its provided configurations. In this paper we consider two molecular complexes: the tryptophan-cage protein (Brookhaven Protein Data Bank ID 1L2Y) and α-cyclodextrin. The experimentation results obtained on a computational grid show the effectiveness of the approach.
Autre [cs.OH]
hal-00684579 , version 1 (02-04-2012)
Alexandru-Adrian Tantar, Nouredine Melab, El-Ghazali Talbi, Benjamin Parent, Dragos Horvath. A Parallel Hybrid Genetic Algorithm for Protein Structure Prediction on the Computational Grid. Future Generation Computer Systems, 2006, 23 (3), pp.398-409. ⟨10.1016/j.future.2006.09.001⟩. ⟨hal-00684579⟩
123 Consultations
0 Téléchargements
