Analysis-suitable volume parameterization of multi-block computational domain in isogeometric applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2013
Parameterization of computational domain is a key step in isogeometric analysis just as mesh generation is in finite element analysis. In this paper, we study the volume parameterization problem of multi-block computational domain in isogeometric version, i.e, how to generate analysis-suitable parameterization of the multi-block computational domain bounded by B-spline surfaces. Firstly, we show how to find good volume parameterization of single-block computational domain by solving a constraint optimization problem, in which the constraint condition is the injectivity sufficient conditions of B-spline volume parametrization, and the optimization term is the minimization of quadratic energy functions related to the first and second derivatives of B-spline volume parameterization. By using this method, the resulted volume parameterization has no self-intersections, and the isoparametric structure has good uniformity and orthogonality. Then we extend this method to the multi-block case, in which the continuity condition between the neighbor B-spline volume should be added to the constraint term. The effectiveness of the proposed method is illustrated by several examples based on three-dimensional heat conduction problem.
133paper.pdf (852.98 Ko) Télécharger le fichier
hal-00685002 , version 1 (03-04-2012)
hal-00685002 , version 2 (19-08-2012)
Gang Xu, Bernard Mourrain, Régis Duvigneau, André Galligo. Analysis-suitable volume parameterization of multi-block computational domain in isogeometric applications. Computer-Aided Design, 2013, Special Issue on Solid and Physical Modeling 2012, 45 (2), pp.395-404. ⟨10.1016/j.cad.2012.10.022⟩. ⟨hal-00685002v2⟩
420 Consultations
693 Téléchargements
