Implicitization of surfaces in P 3 in the presence of base points, J. Algebra Appl, vol.2, issue.2, pp.189-214, 2003. ,
Matrix representations for toric parametrizations, Comput . Aided Geom. Design, vol.26, pp.757-771, 2009. ,
Matrix representations for toric parametrizations. arXiv :0807.4802 ; to appear in Computer Aided Geometric Design, 2009. ,
The surface/surface intersection problem by means of matrix based representations ,
Matrix-based Implicit Representations of Rational Algebraic Curves and Applications, Computer Aided Geometric Design, vol.27, issue.9, pp.681-699, 2010. ,
Degree, multiplicity , and inversion formulas for rational surfaces using u-resultants, Computer Aided Geometric Design, vol.9, issue.2, pp.93-108, 1992. ,
On the validity of implicitization by moving quadrics of rational surfaces with no base points, J. Symbolic Comput.. Vol. Num, vol.29, issue.3, pp.419-440, 2000. ,
Matrix computations , third ed. Johns Hopkins Studies in the Mathematical Sciences, 1996. ,
Implicitization of rational surfaces using toric varieties, Journal of Algebra, vol.303, issue.2, pp.543-565, 2006. ,
DOI : 10.1016/j.jalgebra.2005.05.028
Spectral problems for pencils of polynomial matrices. methods and algorithms v, Journal of Mathematical Sciences, vol.79, issue.3, pp.1048-1076, 1996. ,
Methods and algorithm of solving spectral problems for polynomial matrices and rational matrix, Journal of Mathematical Sciences, vol.96, issue.3, pp.3085-3287, 1999. ,
Curve/surface intersection problem by means of matrix representations, In SNC, pp.71-78, 2009. ,
