Adaptive decomposition and remapping algorithms for object-space-parallel direct volume rendering of unstructured grids, Journal of Parallel and Distributed Computing, vol.67, issue.1, pp.77-99, 2007. ,
DOI : 10.1016/j.jpdc.2006.05.005
A repartitioning hypergraph model for dynamic load balancing, J. Parallel Distrib. Comput, vol.69, issue.8, pp.711-724, 2009. ,
A tensor-based algorithm for high-order graph matching, CVPR, pp.1980-1987, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01063322
Adaptation au repartitionnement de graphes d'une méthode d'optimisation globale par diffusion, Proc. RenPar'20, 2011. ,
Computers and Intractibility: A Guide to the Theory of NP-Completeness, 1979. ,
Dynamic load balancing in computational mechanics, Computer Methods in Applied Mechanics and Engineering, vol.184, issue.2-4, pp.485-500, 2000. ,
DOI : 10.1016/S0045-7825(99)00241-8
Skewed graph partitioning, Eighth SIAM Conf. Parallel Processing for Scientific Computing, 1997. ,
Performance analysis of dynamic load balancing algorithms with variable number of processors, Journal of Parallel and Distributed Computing, vol.65, issue.8, pp.934-948, 2005. ,
DOI : 10.1016/j.jpdc.2005.04.003
A spectral technique for correspondence problems using pairwise constraints, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.1482-1489, 2005. ,
DOI : 10.1109/ICCV.2005.20
PLUM : Parallel Load Balancing for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.52, issue.2, pp.150-177, 1998. ,
DOI : 10.1006/jpdc.1998.1469
Dynamic partitioning of non-uniform structured workloads with spacefilling curves. Parallel and Distributed Systems, IEEE Transactions on, vol.7, issue.3, pp.288-300, 1996. ,
Multilevel Diffusion Schemes for Repartitioning of Adaptive Meshes, Journal of Parallel and Distributed Computing, vol.47, issue.2, pp.109-124, 1997. ,
DOI : 10.1006/jpdc.1997.1410
Partitioning and Dynamic Load Balancing for the Numerical Solution of Partial Differential Equations, Numerical Solution of Partial Differential Equations on Parallel Computers, pp.55-88, 2006. ,
DOI : 10.1007/3-540-31619-1_2
Dynamic load balancing with a spectral bisection algorithm for the constrained graph partitioning problem, High-Performance Computing and Networking, pp.392-397, 1995. ,
DOI : 10.1007/BFb0046658
