Incremental Multi-Classifier Learning Algorithm on Grid'5000 for Large Scale Image Annotation
With our previous research, active learning with multi-classifier showed considering performance in large scale data but much calculation was involved. In this paper, we proposed an incremental multi-classifier (SVM classifiers were used) learning algorithm for large scale imbalanced image annotation. For further accelerating the training and predicting process, Grid'5000, French National Grid, was adopted. The result show that the best performance was reached with only 15-30% of the corpus annotated and our new method could achieve almost the same precision while save nearly 50-60% or even more than 94% of the calculation time when parallel multi-threads were used. Our proposed method will be much potential on very large scale data for less processing time.
