Conference papers
DimaX: A Fault Tolerant Multi-Agent Platform
Abstract : Fault tolerance is an important property of large-scale multi-agent systems as the failure rate grows with both the number of the hosts and deployed agents, and the duration of computation. Several approaches have been introduced to deal with some aspects of the fault-tolerance problem. However, most existing solutions are ad hoc. Thus, no existing multi-agent architecture or platform provides a fault-tolerance service that can be used to facilitate the design and implementation of reliable multi-agent systems. So, we have developed a fault-tolerant multi-agent platform (named DimaX). DimaX deals with fail-stop failures like bugs and/or breakdown machines. It brings fault-tolerance for multi-agent applications by using replication techniques. It is based on a replication framework (named DARX).
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00687173
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Thursday, April 12, 2012 - 3:07:22 PM
Last modification on : Friday, January 21, 2022 - 3:21:53 AM
Identifiers
Citation
Nora Faci, Zahia Guessoum, Olivier Marin. DimaX: A Fault Tolerant Multi-Agent Platform. SELMAS 2006 - 5th Workshop on Software Engineering for Large-Scale Multi-Agent Systems, May 2006, Shanghai, China. ⟨10.1145/1138063.1138067⟩. ⟨hal-00687173⟩
Share
Metrics
Record views
100
