Light P2P platform of computing for DAG
Abstract : HiPoP is a P2P platform of computing platforms.We did the same with other kind of DAG specialized in the execution of applications as DAG and we obtained quite the same. Results show that (Directed Acyclic Graph). This platform works in an HiPoP is efficient even if it is simple and unequipped heterogeneous environment and relies on the of an optimal scheduler or other managers. portability ofthe JAVA language. We present in a first section some notions and HiPoP Performances are compared to Condor and essentialnotations relative to task dependences. Then show an ease of use and good performances. The we go through HiPoP architectures following and its security of our system is based on the concept of functioning. Next, we move on to the test scenario we sandboxing.
Type de document :
Communication dans un congrès
IEEE. DFMA'06 : The 2nd International Conference on Distributed Frameworks for Multimedia Applications, May 2006, Penang, Malaysia. IEEE, pp.49-54, 2006, 〈10.1109/DFMA.2006.296894〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00689139
Contributeur : Ist Rennes <>
Soumis le : jeudi 19 avril 2012 - 13:19:03
Dernière modification le : jeudi 15 février 2018 - 08:48:07
Citation
Fabien Hantz. Light P2P platform of computing for DAG. IEEE. DFMA'06 : The 2nd International Conference on Distributed Frameworks for Multimedia Applications, May 2006, Penang, Malaysia. IEEE, pp.49-54, 2006, 〈10.1109/DFMA.2006.296894〉. 〈hal-00689139〉
Métriques
Consultations de la notice
44
